770
All operating systems freeze sometimes, and Ubuntu is no exception. What should I do to regain control when...
  • just one program stops responding?
  • nothing at all responds to mouse clicks or key presses?
  • the mouse stops moving entirely?
  • I have an Intel Bay Trail CPU?
In what order should I try various solutions before deciding to pull the power plug?
What should I do when starting up Ubuntu fails? Is there a diagnostic procedure I can follow?
Zanna
  • 72,312
ændrük
  • 78,496
47 Answers47
644
If it locks up completely, you can REISUB it, which is a safer alternative to just cold rebooting the computer.
REISUB by:
While holding Alt and the SysReq (Print Screen) keys, type REISUB.
R:  Switch to XLATE mode
E:  Send Terminate signal to all processes except for init
I:  Send Kill signal to all processes except for init
S:  Sync all mounted file-systems
U:  Remount file-systems as read-only
B:  Reboot
Some mnemonics for REISUB:
  • Rise up (from the dead) if you're inclined to zombie movies
  • BUSIER backwards, as in The System is busier than it should be!
  • Reboot Even If System Utterly Broken.
  • Or the classic: Raising Elephants Is So Utterly Boring
This is the SysReq key:
SysReq key
NOTE: There exists a less radical way than rebooting the whole system. If SysReq key works, you can kill processes one-by-one using Alt+SysReq+F. Kernel will kill the mostly «expensive» process each time. If you want to kill all processes for one console, you can issue Alt+SysReq+K.
NOTE: You should explicitly enable these key combinations. Ubuntu ships with sysrq default setting 176 (128+32+16), which allows to run only SUB part of REISUB combination. You can change it to 1 (all commands enabled) or 244 which is potentially less harmful. To do this:
sudo nano /etc/sysctl.d/10-magic-sysrq.conf
and switch 176 to 244; then
echo 244 | sudo tee /proc/sys/kernel/sysrq
It will immediately work! You can test this by pressing Alt+SysReq+F. For me, it killed the active browser tab, then all extensions. And if you will continue, you can reach X Server restart.
More info on all the Alt+SysReq functions here.
Phoenix
  • 6,549
490
When a single program stops working:
When a program window stops responding, you can usually stop it by clicking the X-shaped close button at the top left of the window. That will generally result in a dialog box saying that the program is not responding (but you already knew that) and presenting you with the option to kill the program or to continue to wait for it to respond.
Sometimes this does not work as expected. If you can't close a window by normal means, you can hit Alt+F2, type xkill, and press Enter. Your mouse cursor will then turn into an X. Hover over the offending window and left-click to kill it. Right clicking will cancel and return your mouse to normal.
If your program is running from a terminal, on the other hand, you can usually halt it with Ctrl+C. If not, find the name and process ID of its command, and tell the program to end as soon as possible with kill [process ID here]. It sends the default signal SIGTERM (15). If all else fails, as a last resort send SIGKILL (9): kill -9 [process ID here]. Note that you should only use SIGKILL as a last resort, because the process will be terminated immediately by the kernel with no opportunity for cleanup. It does not even get the signal - it just stops to exist.
(Killing a process by kill -9 allways works if you have the permission to kill. In some special cases the process is still listed by ps or top (as "zombie") - in this case, the program was killed, but the process table entry is kept, becuse it's needed later.)
When the mouse stops working:
If the keyboard still works, press Alt+F2 and run gnome-terminal (or, if these fail to launch, press Alt+Ctrl+F1 and login with your username and password). From there you can troubleshoot things. I'm not going to get into mouse troubleshooting here, as I haven't researched it. If you just want to try restarting the GUI, run sudo service lightdm restart. This should bring down the GUI, which will then attempt to respawn, bringing you back to the login screen.
When you have an Intel Bay Trail CPU
See https://askubuntu.com/a/803649/225694.
When everything, keys and mouse and all, stop working:
First try the Magic SysReq method outlined in Phoenix' answer. If that doesn't work, press the Reset button on the computer case. If even that doesn't work, you'll just have to power-cycle the machine.
May you never reach this point.
UTF-8
  • 5,910
  • 34
  • 68
koanhead
  • 6,547
64
You can make the shortcut Ctrl+Alt+Delete open the System Monitor, with which you can kill any unresponsive applications.
  1. Open up System ➜ Preferences ➜ Keyboard Shortcuts and click Add.
    In the Command field, enter gnome-system-monitor. Name the shortcut whatever you want.
  1. Click Apply and then click where it says Disabled. Now hit the keys Ctrl+Alt+Delete
  1. Close Keyboard Shortcuts and try out the shortcut:
edwinksl
  • 24,109
Isaiah
  • 60,750
48
Freezes such as you have described can be both software and hardware related and as you have found sometimes frustratingly difficult to diagnose.
Hardware
If this is a desktop PC look at your hardware-cards. For both laptops and desktops possibly acpi type issues.
It might be useful to temporarily simplify your configuration to have just the graphics card connected with a standard keyboard and mouse. All other cards should be removed.
For acpi related issues, try booting with noapic nomodeset in your grub boot option. Its also worth trying acpi=off although this could have other undesirable effects such as constant fan usage.
Also worth checking the bios version level and seeing if the vendor has a newer bios version. The readme notes should hopefully reveal if any newer version fixed crashes and freezes.
Software
I note you have tried the standard 270 drivers but have failed due to freezes. Can you clarify if you had similar issues with the open-source driver? Obviously you will not get Unity during testing this.
Graphics freezing can be one of/or a combination of the driver/compiz/X/kernel
If you are willing to try any of the suggestions below first backup your system with a good backup tool such as CloneZilla. You will need an external media device to receive the image such as a large USB stick/drive or separate internal hard-drive.
Installing newer nVidia driver
Deactivate (uninstall) your current 173-nvidia driver using the Additional Drivers window.
There are a small number of important fixes primarily in the 275 stable but a small number also in the 280beta that fixed freezes - it is worth a shot to see if these apply to your graphics card. Unfortunately nvidia dont go into detail on which cards they specifically fix (readme.txt)
However - I would strongly recommend a backup unless you feel confident on reversing a nvidia install - especially since you had serious issues with the slightly older 270 drivers. I've used clonezilla countless times and it has always got me out of trouble. You do need a large external drive though - USB stick/external drive or a separate drive.
X Updates
The latest graphics drivers have been packaged in the x updates ppa.
Note - this will lead you away from the standard baseline - if upgrading in the future ppa-purge the PPA itself before upgrading.
You can also manually install the drivers from nVidia:
Try installing the latest nvidia stable 275 or 280 drivers - 32bit 280 drivers: ftp site and 64bit: 280 drivers: ftp site
To Install
CTRL + ALT + F1 to switch to TTY1 and login
sudo service gdm stop
To stop the X server
sudo su
To run as root
cd ~/Downloads
sh NVIDIA-Linux-x86-280.04.run
To install the 32bit driver (equiv for 64bit) then reboot.
To uninstall
sudo sh NVIDIA* --uninstall
Also remove /etc/X11/xorg.conf
X/Kernel/Compiz
If you run classic Ubuntu with effects do you get the same freeze issues as standard Ubuntu? If you cannot reproduce the freeze with classic Ubuntu (no effects) then this will point you towards a compiz issue. I would raise a launchpad bug report with the compiz team.
If space is available (e.g. 20Gb), you could dual boot/install alongside the latest oneiric alpha. Obviously this will itself be unstable, but it will come with the latest X and Kernel. You may need to also install manually the beta 280 graphics drivers above since it probably will not be offered in the Additional Drivers window.
If during testing you dont see the same freeze activity you could try uplifting your X version with the x-edgers ppa and using kernel kernel 3.0 in Natty. Going this route is not really desirable - and could cause you upgrade issues in the future - and may have other unforeseen stability issue. Again, use ppa-purge to remove the PPA.
Kernel 3.0 is packaged with the PPA - you'll need to install the headers as well as the kernel itself from synaptic BEFORE rebooting if you intend to install the nvidia drive later.
This is a testing ppa - do have a ready backup if you want to try this route.
fossfreedom
  • 174,526
39
If you're getting a lot of freezes, there might be something wrong with your hardware. I used to get hard lockups every 48 hours due to some less than optimal RAM. Memtest86+ showed the fault after 40 minutes of testing. Swapped the RAM out for some more (under warranty) and I'm now at 32 days, 1 hour of uptime.
Ubuntu doesn't tend to leak its guts all over your memory like Windows can over time. Even if one application or a poor X video driver does, you can restart LigthtDM very simply and just keep going and going and going. I've actually been through three beta versions of the nvidia driver in this one boot :)
Anyway... While knowing how to restart softly is a very handy thing, finding, reporting and fixing the system should be your next priority. If it's an always-on system, you should easily be able to make it between kernel updates* without needing a restart.
*You should restart when you get kernel updates as they'll be security fixes that won't be applied until you reboot into the newer kernel.
Jjed
  • 14,064
Oli
  • 299,380
37
When everything stops working, first try Ctrl + Alt + F1 to go to a terminal, where you can likely kill X or other problem processes.
If even that doesn't work, try using holding down Alt + SysReq while pressing (slowly, with a few seconds between each) R E I S U B.
This puts the keyboard in raw mode, ends tasks in various states, syncs the disks, etc, and finally reboots the machine. You will get much better results doing this than just pulling the plug. Of course, if this fails, you're pretty much left with pulling the plug.
Octavian Helm
  • 14,515
Nerdfest
  • 4,658
33
Also, sometimes it's simply the X-Server which hangs - a case I've most often found when you're using Compiz.
If this is the case you can kill X, which will restart and drop you back at the log-in screen.
The default sequence is Ctrl + Alt + Backspace
Although this is turned off by default (presumably new-users were accidentally hitting it) and can be turned back on like this:
  1. SystemKeyboard (i.e. the Keyboard Preferences Dialogue)
  2. Layouts tab
  3. Click the Options button
  4. At the Key Sequence to kill the X server point check Ctrl + Alt + Backspace.
30
My first favourite when total freeze occured - Alt + SysRq + K.
That combo kills X, and returns me to the graphical login screen. If that doesn't work, try Alt + SysRq + R E I S U B.
Jjed
  • 14,064
Extender
  • 2,356
19
In such cases you can try CTRL-ALT-F1 to get to a console. Then login with your password.
Restarting the GUI
You can try to restart your graphical desktop with:
If you're running Ubuntu 11.04 or earlier, you should use this instead (as gdm used to be the default display manager):
sudo service gdm restart
If you're using Kubuntu instead, then the default display manager is kdm, so you should instead use:
sudo service kdm restart
If you're using another display manager, replace ligthdm/gdm/kdm with its name.
Restarting the Machine
If you want to do a clean system reboot, use:
sudo shutdown -r now
Floyd
  • 1,801
  • 15
  • 16
19
What I do is opening a terminal with eg. Ctrl + Alt + F2
Login and use the terminal to kill the process that is lagging
ps -e | grep <procesname>
This shows the processID of the process with that name
(sudo) kill <processID>
This shuts down the process safely, in case that doesn't work use
(sudo) kill -9 <processID>
Use the man pages for more information about these commands.
You can get back to the graphical user interface with Ctrl + Alt + F7
Octavian Helm
  • 14,515
Chielus
  • 291
19
DoR and Phoenix has answered this well. To make this page more complete I would add:
If it is only X that is "broken", than you can use kernel to kill it:
SysRq + Alt + K
For laptops (depends on the model, typically needed if "SysRq" is written in blue):
Fn + SysRq + Alt + K (release Fn after pressing SysRq).
desgua
  • 33,215
15
To diagnose the freezes you should be able to use the net console (or serial serial console for that matter). Follow the set up instructions outlined here.
Li Lo
  • 16,382
15
The first thing to look at is if it is just X that's frozen, or the whole system. Enable ssh and then ssh into the system. If you can't ssh into it, then it's probably a kernel lock up. If you can ssh in, then it might be just a gpu lockup.
Next try restarting X. Do this by restarting the display manager:
  • On Ubuntu 11.10 and later, LightDM is the display manager, so run:
  • On Ubuntu 11.04 and earlier, GDM is the display manager, so run:
    service gdm restart
If that works, then it's perhaps an X bug. If it still doesn't work, then you may have a GPU lockup in the kernel drm driver. It would be useful to know at this point whether you're running the -ati (open source) driver, or -fglrx (closed source) driver.
Jjed
  • 14,064
Bryce
  • 4,740
13
If you ever use the magic SysRq key as suggested in the first answer, just try getting the keyboard to work first with Alt + SysRq + R; then try Ctrl + Alt + F1 again.
It may work and you may save yourself a reboot. Only if it doesn't work you should try the whole REISUB sequence.
Octavian Helm
  • 14,515
12
If you have to do a hard shutdown I'd be wondering if the memory (RAM) was failing. On your next boot, try running memtest86. To do this:
  • while booting, hold down a shift key
  • the GRUB menu will appear
  • use the cursor keys to select the last option "memtest86"
  • press enter
You'll get a basic display and it will try reading and writing lots of values to all of your RAM. As long as there are no failures, you'll see a green status. If there is any failure it will turn red. In that case you'll need to replace at least one stick of your RAM.
There is also community documentation of diagnosing hardware failures.
Hamish Downer
  • 19,506
11
Just press Ctrl + Alt + F1 on your keyboard to open TTY1. When it opens, run the kill command. An example is below.
First you use ps.
This will show you all processes running (ps | less if you want to see the results page by page).
Then you look for the PID of the process you want to terminate. After this use: kill pid
kill command- Stop a process from running
Syntax: kill [-s sigspec] [-n signum] [-sigspec] jobspec or pid kill -l [exit_status]
Description: Most modern shells, Bash included, have a built-in kill function. In Bash, both signal names and numbers are
accepted as options, and arguments may be job or process IDs. An exit status can be reported using the -l option: zero when at least one signal was successfully sent, non-zero if an error occurred. Using the kill command from /usr/bin, your system might enable extra options, such as the ability to kill processes from other than your own user ID and specifying processes by name, like with pgrep and pkill. Both kill commands send the TERM signal if none is given.
Extra: Use Ctrl+Alt+Del for Task Manager in Linux to Kill Tasks Easily
Mitch
  • 109,787
I thinks there is no such thing as a perfect distro, even in Windows they have this screen of death.
  • Open another terminal Ctrl + Alt + F2.
  • Login with your username and password.
  • Issue this command:
    sudo /etc/init.d/gdm restart
    This restarts or logs you out of your current session but it will not reboot.
Then Ctrl + Alt + F7 go get back to your graphical interface.
Octavian Helm
  • 14,515
dsaint
  • 774
(Community wiki answer - solution was originally buried in the OP question)
SOLUTION:
Solved it.
My particular problem was my graphics card (integrated Radeon 9000 series). netconsole revealed I was getting the error: "reserve failed for wait". After trial-and-error, I manually configured my video card and disabled hardware acceleration. Completely fixed the issue.
Here is what I did:
Manually Created xorg.conf
Ubuntu automatically configures xorg.conf and doesn't use a file. To edit this file, you have to tell Ubuntu to explicitly create one and then edit it. Here are the steps:
  1. Restart system
  2. Hold Shift as GRUB boots
  3. Select root terminal in GRUB login menu
  4. Execute: X -config xorg.conf.new
  5. Copy: cp xorg.conf.new /etc/X11/xorg.conf
Disable Hardware Acceleration
The following is specific to my Radeon card, but I'm sure other cards have a similar setup.
  1. Edit xorg.conf
  2. Find "Device" section for graphics card
  3. Uncomment "NoAccel" option and set to "True"
  4. Save + reboot
Hope that helps.
fossfreedom
  • 174,526
You can always do Alt + F2 and write killall <program> or xkill and click on the window you want smashed!
Octavian Helm
  • 14,515
You might get some extra information when you switch to the TTY view. Press Ctrl + Alt + F1 to get this, use Ctrl + Alt + F7 (or maybe F8) to get back to the GUI. You can have different sessions on most of the F-keys but that's different question altogether.
Skizz
  • 531
My ubuntu is super prone to freezing (probably 20 odd times a day). I use the magic sysrq key too, but instead of using it to reboot or kill xserver, I use the 'f' command which calls oom_kill, effectively dropping a process. I've only ever seen this drop chrome tabs (as I tend to have quite a few heavyweight ones open at a time). Anyway, this get's me out of this mess 95% of the time.
So when my ubuntu freezes (locks up, mouse stops responding etc), I hold alt + sysrq and then hit f (if you don't do this correctly it will take a screenshot instead). I usually have to repeat this combo a couple of times before ubuntu spurs back to life.
I'd have given up on ubuntu a long time ago if I hadn't discovered this, hope it helps someone!
unohoo
  • 151
The simplest solution is to add the "Force Quit" applet to your Gnome top panel and when a program doesn't respond, click on the force quit and then on the application.
I am surprised with so many answers, this isn't mentioned. Of course, you can always do a ps -A and pipe that to grep for your program name. And kill -9 that. I prefer simplicity.
Octavian Helm
  • 14,515
lprsd
  • 269
To debug the freeze, you can use Magic SysRq key, for example:
Note: Consider holding ⇧ Shift (depending on your keyboard).
  • Alt-SysRq-9 (no ⇧ Shift) - Set the console log level to 9 to show more of kernel messages
  • Alt-SysRq-w - Display list of blocked (D state) tasks
  • Alt-SysRq-l - Shows a stack backtrace for all active CPUs.
  • Alt-SysRq-t - Output a list of current tasks and their information to the console
  • Alt-SysRq-p - Output the current registers and flags to the console
  • Alt-SysRq-q - Display all active high-resolution timers and clock sources.
  • Alt-SysRq-m - Output current memory information to the console
Other things to try during freeze:
  • Reset the nice level of all high-priority and real-time tasks by hitting Alt-SysRq-n.
  • Try forcing a return to a text console try hitting Control-Alt-F1 (from F1 to F12).
  • Kill all processes on the current virtual console (can kill X) by hitting Alt-SysRq-k.
  • Perform a system crash (if it is configured) by Alt-SysRq-c.
If nothing works, you should perform a safe reboot by Alt-SysRq-REISUB, which is:
  • Alt-SysRq-R: UnRaw (take control of keyboard back from X).
  • Alt-SysRq-E: tErminate (send SIGTERM to all processes).
  • Alt-SysRq-I: kIll (send SIGKILL to all processes, forcing them to terminate immediately).
  • Alt-SysRq-S: Sync all mounted filesystems (flush data to disk).
  • Alt-SysRq-U: Unmount (remount all filesystems in read-only mode),
  • Alt-SysRq-B: immediately reBoot the system.
    Note: If above hard reboot combination won't work, the freeze could be caused by defected hardware, not video drivers.
If you can't use Magic SysRq key, see also: Diagnosing and fixing apparently random Ubuntu crashes?
After reboot, check your kern.log for details, especially call traces generated by above kernel commands. This can help to find the right bug report for it, and find the solution. Check the following kern.log example.
You can check the latest crash log by:
journalctl -b -1 # Then hit Shift-G to jump to the end.
To list other journal logs, run:
journalctl --list-boots
Suggested solution:
  • Upgrade your Ubuntu and kernel to the latest version.
  • If problem repeats, the workaround is to install NVIDIA drivers, which replaces Nouveau video driver.
See also:
kenorb
  • 10,944
Hit Alt+F2 to run a command. Type xkill and hit Enter.
Your mouse cursor will transform into a cross that can force to close any window you click on.
If somebody can provide a screenshot, I think that would be useful.
Agmenor
  • 16,394
There were some missed bugs between the relation of Unity/Compiz, the X.org system and the Video driver. These bugs of course are dealt with with newer, updated versions of Unit, Compiz, X or the video Driver.
When inside Unity and everything is slow and basically damaged, to go to TTY1, press CTRL+ALT+F1. When in the terminal, type your user and password to get to the prompt line. You can also get to the TTY when booting by pressing ESC or holding SHIFT, then on the GRUB menu, selecting recovery mode.
  1. Install Xorg Edgers PPA
    sudo add-apt-repository ppa:xorg-edgers/ppa sudo apt-get update
    Depending on your video card you can either install the 304 series, 310 Series, 313 Series or any newer one that appears there. I recommend always test the latest version and only if it throws a problem, then go down from there until you reach a version where everything works correctly. For example, if you have a GT 9500 or later (Like in my case to which I also have a 440 GT, 560 TI and 680 GTX) the only version that solves all my problems is the 313.18 that came out a couple of days ago. So I would do this:
    sudo apt-get install nvidia-313
    This would install the latest version of the 313 series. It fixes MANY video problems with compiz, unity and xorg. The 310 series also fixes many issues but have not tested that one with my video cards. The other Nvidia versions are nvidia-experimental-304 and nvidia-experimental-310 as of this writing.
  2. Reboot to test if your video card not works correctly with Ubuntu. If you get any problems regarding Nvidia config file, simply open a terminal and type sudo nvidia-xconfig and reboot.
There are other nice questions that could also help like:
How can I update my NVIDIA driver?
How do I install the Nvidia drivers?
Can not install Nvidia driver
What's the difference between the nvidia-current, and nvidia-current-updates packages?
Or even one that is more generic: How to correctly enable Desktop Cube in Unity 3D?
Luis Alvarado
  • 216,643
In the very specific case you are using Virtualbox to run a 64-bit guest on a 32-bit (Ubuntu) host using VT-x or AMD-V (hardware virtualization technology built-in your CPU) only
Virtualbox may make your 32-bit host randomly crash when you run a 64-bit guest on it using VT-x or AMD-V (hardware virtualization technology built-in your CPU). It is a known issue.
2 solutions:
  1. You have to run 32-bit guests only on your current 32-bit host [recommended if you have less than 2 GB of RAM];
  2. You have to switch to Ubuntu 64-bit as host (you can even perform a 32-bit to 64-bit "migration" by reinstalling Ubuntu 64-bit without touching to your "/home" folder) [recommended if you have 2 GB of RAM or more].
Please note that you can run 64-bit and 32-bit guests on a 64-bit host using Virtualbox without any problem.
Other answers have very well covered general cases...
Golboth
  • 1,422
Replace with the latest Linux kernel 2.6.35 or up that will solve your problem. Follow these steps from this link.
I was having similar issues with 10.04. X would hang and and nothing but a reset would fix it. I updated my nvidia drivers to the latest version and I haven't had issues since.
if possible, try to open an ssh shell from another computer. this is an option If you knew in advance that the computer might hang soon, open the connection first before you perform that task.
I do this sometimes when I know vmware runs crazy and the GUI of ubuntu (the vmware host) becomes unresponsive. I can do a suspend from the ssh shell, it might take a while until it gets thru, and after a while the computer is idle again.
knb
  • 5,292
If you have tried all of the above and the freezing problem remains, you might want to try what I did.
Apply generous amounts of contact cleaner to CPU, RAM and any other chip complex enough to show those tiny, tightly packed pins. They can lose conductivity from dust accumulation as well as shorting due to humidity.
Some days after the cleaning (I used CRC 2-26) and a series of really brutal stress tests, my PC hasn't frozen once.
So, for all of you getting sudden unexpected freezings, give up messing around with your OS beyond what's reasonable and do an exhaustive dust and contact cleaning.
Zanna
  • 72,312
  1. Press Ctrl+alt+t to get the terminal, then find the hanging process (ps -ef | grep ) then kill it using pid found (kill -9 )
  2. Press Ctrl+alt+F2 (in some cases fn key also to be pressed) to enter single user mode. Login and restart lightdm/kdm service
sudo service start lightdm.
  1. Graceful reset press alt+print screen+r+e+i+s+u+b
  2. If still issue, then power off button is last resort :)
IamSushil
  • 124
I have found that the culprit in my case was plain and simple overheating. I live in a warmer climate and if I am not running airconditioning my laptop starts locking up. Pointing a fan directly at it resolved the problem.
Zanna
  • 72,312
One of the solutions I found that stopped my computer from freezing was to stop the cpu scheduler setting itself to ondemand. This is found in the /etc/init.d/ondemand script.
I just renamed the file.
sudo mv /etc/init.d/ondemand /etc/init.d/ondemand.bk
This breaks all the symbolic links to ondemand. So it won't start up at boot time. This will put some error messages into your log.
A better way is to use update-rc.d. I was lasy and have not tried these commands.
sudo update-rc.d -f ondemand remove
Or:
sudo update-rc.d ondemand stop 2 3 4 5 S
To start it again:
sudo update-rc.d ondemand Start 2 3 4 5 S
Although starting it again caused my computer to free again. So I left it disabled.
Zanna
  • 72,312
nelaaro
  • 10,338
If you are able to switch between applications, and not able to use them (for example, unable to change tabs in a browser or scroll) Ubuntu 18.04 LTS, just click the log out button and press Cancel instead of logging out. This will restore the original unfrozen state.
If you are using motherboard of intel 8xx, then I would strongly recommend to migrate to Ubuntu 10.10 Maverick Meerkat, I think they have solved the Xorg related bugs.
I had faced the same problems but once I installed Ubuntu 10.10 Maverick Meerkat, I have never faced any Xfreeze issue.
I have Ubuntu 12.04 LTS installed on Lenovo Thinkpad core i5, it kept on freezing completely and I had to manually restart it by power cycle. I solved it by updating my Ubuntu kernel to latest version. It might fix your problem too. Here are the instructions to do that:
1- Go here: http://kernel.ubuntu.com/~kernel-ppa/mainline/ Download 3 (maybe 4) debs to a folder somewhere:
  • linux-headers-VERSION-NUMBER_all.deb
  • linux-headers-VERSION-NUMBER_amd64.deb
  • linux-image-VERSION-NUMBER_amd64.deb
  • linux-image-extra-VERSION-NUMBER_amd64.deb # if available
2- Install the debs with whatever package manager front-end you use (for example, Gdebi), or use these commands:
cd /path/to/folder/where/you/put/the/debs
sudo dpkg -i *.deb
Source: How to update kernel to the latest mainline version without any Distro-upgrade?
codefreak
  • 276
I had a custom built PC keep freezing on me. I put the temperature sensors in the gnome panel and was able to see if the CPU, HDD, Motherboard (basically any system temp) were getting hot at the time of the lock.
Your ATI card might be running hot and you need increased airflow.
Phil Hannent
  • 1,595
I have a simple fix for random freezes happening under Ubuntu 12.04 (kernel 3.5.0-41) on HP DV7, just use unity_2d :
sudo vi /etc/lightdm/lightdm.conf
Replace user-session=ubuntu with user-session=ubuntu-2d
sudo reboot
More info on http://cleanstructions.blogspot.fr/2013/10/fix-random-freezes-ubuntu-1204.html
Memtest passed many times and it just happened from one day to the other, possibly after an upgrade. I just couldn't investigate the kernel panic, the whole system was locked and logs (when available) were not displaying anything relevant to me.
Has anyone has an idea about what is wrong with my graphics card for not supporting open GL anymore?
Zanna
  • 72,312
For those who:
  • have screen freezes but applications are still working
  • and you can do Ctrl + Alt + F1
  • and you have no other option but to restart (service lightdm restart doesn't work)
  • and you have too many applications open and don't want to lose your session
Maybe you can:
  • go do the Ctrl + Alt + F1
  • run pm-suspend (will suspend the machine)
  • start the machine; you should get the machine back to the state before the screen freezes (at least for me it did)
I've tried all solutions suggested above, but none of them work or part of it worked but I was still forced to restart the machine and lose all running applications. This is not the best solution but at least I don't lose the applications I need when working.
hg8
  • 13,582
Dranzd
Before you try the next key combination, please remember that Ctrl+Alt+F7 brings you back. Remember? Really? OK, then: If the Ubuntu GUI doesn't show up or freezes just use Ctrl+Alt+F1 to switch to a terminal.
You should have pressed Ctrl+Alt+F7 to see this message again.
It is the easiest solution, but not permanent, after that your Ubuntu can continue to freeze, but you can repeat this process every time, when Ubuntu freezes. :)
Fabby
  • 35,017
In my case compiz causes the freezing; I can move mouse cursor, but mouse clicks do nothing. The keyboard works, so, my recipe is restarting compiz
  1. Press Ctrl + Alt + F1
  2. Run this command:
    killall -9 compiz
  3. Press Ctrl + Alt + F7
Zanna
  • 72,312
Oleg Svechkarenko
  • 153
After suffering with this for over a year I worked around the problem by using Xfce as the desktop environment. I simply installed it using APT: sudo apt-get install xfce4
I have a 2009 PC with in-built graphics and it intermittently had problems every time graphics settings were adjusted (whether via Ubuntu's auto updates or not I'm not sure).
I suppose I could have given Unity 2D a try but Xfce works.
Zanna
  • 72,312
First of all use the top command in the terminal to see the PID of the unresponsive program Top Function in Terminal Then kill -9 "pid" without the quotes.
If the nothing at all responds to your click and key strokes or your mouse stops working then press Ctrl+Alt+F1 and restart the display manager by running:
sudo service lightdm start     # Ubuntu 12.04/14.04
or
sudo systemctl start graphical.target     # Ubuntu 16.04 and later
If it fails, don't worry. Pressing Ctrl+Alt+F7 will bring you back to your desktop environment.
Zanna
  • 72,312
Installing the wrong graphics driver was the root of the problem for me.
Using nouveau, stopped the freezing, but it was slow.
I realized by using nvidia-detect that the graphics driver I should install was nvidia-304 for Geforce GT 8500.
Zanna
  • 72,312
ric
On my laptop when it freezes, I'm able to do control + alt + fn + f7, then control + alt + fn+ f2. This gets to the shell, then I login with my username and password. To go back to the desktop I do chvt 8 this gets me back to my current desktop. To find out the active tty's type w then chvt to the current one.
That way you can resume your work without rebooting or losing anything.
answerSeeker
  • 901
  • 26
I just needed to power-cycle the machine after installing the candidate kernels from https://wiki.ubuntu.com/SecurityTeam/KnowledgeBase/SpectreAndMeltdown. No hardware problems here but beware of such side effects when running on non-stable kernels.
Gabor
  • 268
  • 18
