My computer freezes very often when I watch videos on youtube, or if I browse the web. I think that i have a problem with the driver of my graphic card ...
Sony Vaio SVS1311F3E/W
Intel Core i5-3210M à 2,5 GHz (3.1 GHz with Intel Turbo Boost technology).
Memory cache 3 Mo.
Chipset Intel HM76 Express.
RAM 4 Go DDR3.
Hard drive 500 Go SATA.
Graphic card Intel HD Graphics 4000.
Ubuntu 12.04.
Jorge Castro
  • 73,717
Nazim
  • 13
NOTE: These instructions are obsolete. The fix has entered the default repositories. If you are still experiencing freezing, your problem is different from the OP's. Please open a new question about it (after reading What should I do when Ubuntu freezes, of course).
Known bug.
Solution:
  1. Open Update Manager
  2. Click the Settings button
  3. Check the box Pre-released updates
  4. Click the Check button in Update Manager
  5. Install the updates
  6. Reboot
Problem solved.
Optional:
  • Uncheck Pre-released updates in Update Manager settings to avoid getting potentially unstable updates in the future
bessman
  • 7,585
Run a memory test. You will have to select "memory test" from your Grub menu. If it is not available, install the memtest package first. Usually, the Grub menu can be revealed by holding the left Shift key during boot.
Edit: Look, if you are voting this down, at least explain to me why. Memory failure could very well be the cause of such random lockups.
