I'm using Ubuntu 14.04 on Lenovo Yoga 2 Pro frequently (not allways) when I close my computer plugged/unplugged when I open it agin it is frozen.
Some timew when opened the login screen is up but I can't type the password, somtimes the desktop is open, but nothing works, in other cases the screen is just black. The only solution is to force shut down the computer. Is there anything that can be done to prevent this?
I have googled this but i haven't found any solution yet.
A couple of ideas:
  • Type Ctrl-Alt-F1. This should bring you to a terminal (non-graphics) console with a login prompt. You should be able to login here, sudo to root and look at log files under /var/log. This way you may be able to determine exactly what is happening.
  • You may also be able to set the power options by going to System Settings -> Power, and selecting what happens when you close the lid. You can get to System Settings by doing a search in dash (in the launcher, left side of the screen), or by directly clicking on the power meter at the top right of the screen.
