What is the command that is used to reboot the system in case of ubuntu Freezing and unable to do any operation ?
Asked
Active
Viewed 1.7k times
The command you are looking for is known as Reboot Even If System Utterly Bad - REISUB.
So what you need to do is:
Press ALT+Print Screen and then enter the following key combination. REISUB
More details of the command are:
R: Switch the keyboard from raw mode to XLATE mode
E: Send the SIGTERM signal to all processes except init
I: Send the SIGKILL signal to all processes except init
S: Sync all mounted filesystems
U: Remount all mounted filesystems in read-only mode
B: Immediately reboot the system, without unmounting partitions or syncing
Source https://fosswire.com/post/2008/04/ubuntu-cheat-sheet/
Shakti Phartiyal
- 558
