I installed Ubuntu 18.04 on my laptop .it freeze on reboot and shutdown and suspend and I have to manually shutdown with power key for turning off the computer. I tried https://help.ubuntu.com/community/BinaryDriverHowto/Nvidia#Installation the solution with no luck . can anybody help me? I have n552vw laptop with i7 6700hq with the 960gt Nvidia driver
here is sudo blkid output:
/dev/sda2: UUID="148a4a5d-60cf-414e-8ce3-b79f86ad386c" TYPE="ext4" PARTUUID="a4dabba3-3ec9-4fe0-bcd8-fdb26e33d980"
/dev/loop0: TYPE="squashfs"
/dev/loop1: TYPE="squashfs"
/dev/loop2: TYPE="squashfs"
/dev/loop3: TYPE="squashfs"
/dev/loop4: TYPE="squashfs"
/dev/loop5: TYPE="squashfs"
/dev/loop6: TYPE="squashfs"
/dev/loop7: TYPE="squashfs"
/dev/sda1: UUID="6BF5-CC22" TYPE="vfat" PARTLABEL="EFI System Partition" PARTUUID="4b160ac6-a5d2-4f8c-81c9-b02cc025d0cd"
/dev/sdb1: LABEL="New Volume" UUID="7C7A8BDF7A8B9514" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="99a61984-cdc3-477d-9c2b-20b5eff5a457"
/dev/loop8: TYPE="squashfs"
/dev/loop9: TYPE="squashfs"
/dev/loop10: TYPE="squashfs"
/dev/loop11: TYPE="squashfs"
/dev/loop12: TYPE="squashfs"
/dev/loop13: TYPE="squashfs"
/dev/loop14: TYPE="squashfs"
/dev/loop15: TYPE="squashfs"
/dev/loop16: TYPE="squashfs"
/dev/loop17: TYPE="squashfs"
here is /etc/fstab:
  /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
# / was on /dev/sda2 during installation
UUID=148a4a5d-60cf-414e-8ce3-b79f86ad386c /               ext4    errors=remount-ro 0       1
# /boot/efi was on /dev/sda1 during installation
#UUID=6BF5-CC22  /boot/efi       vfat    umask=0077      0       1
/swapfile                                 none            swap    sw              0       0
UUID=6BF5-CC22  /boot/efi   vfat    defaults    0   1
here is free -h
              total        used        free      shared  buff/cache   available
Mem:           7.7G        5.4G        418M        230M        1.9G        1.8G
Swap:          2.0G          0B        2.0G
and last one cat /etc/initramfs-tools/conf.d/resume
cat: /etc/initramfs-tools/conf.d/resume: No such file or directory
sudo fdisk -l output
Disk /dev/loop0: 3.7 MiB, 3878912 bytes, 7576 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop1: 13 MiB, 13619200 bytes, 26600 sectors
Disk /dev/loop2: 34.6 MiB, 36216832 bytes, 70736 sectors
Disk /dev/loop3: 13 MiB, 13619200 bytes, 26600 sectors
Disk /dev/loop4: 1.2 MiB, 1253376 bytes, 2448 sectors
Disk /dev/loop5: 140.9 MiB, 147722240 bytes, 288520 sectors
Disk /dev/loop6: 2.3 MiB, 2355200 bytes, 4600 sectors
Disk /dev/loop7: 14.5 MiB, 15196160 bytes, 29680 sectors
Disk /dev/sda: 119.2 GiB, 128035676160 bytes, 250069680 sectors
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: 6270DE80-FEA1-4548-BE07-17C506FCAD06
Device       Start       End   Sectors   Size Type
/dev/sda1     2048   1050623   1048576   512M EFI System
/dev/sda2  1050624 250068991 249018368 118.8G Linux filesystem
Disk /dev/sdb: 931.5 GiB, 1000204886016 bytes, 1953525168 sectors
Disklabel type: gpt
Disk identifier: 5D1C00F9-28BD-4FF1-9DAF-FC6D770E1A49
/dev/sdb1   2048 1953523711 1953521664 931.5G Microsoft basic data
Disk /dev/loop8: 53.7 MiB, 56311808 bytes, 109984 sectors
Disk /dev/loop9: 140.7 MiB, 147496960 bytes, 288080 sectors
Disk /dev/loop10: 34.7 MiB, 36323328 bytes, 70944 sectors
Disk /dev/loop11: 2.3 MiB, 2433024 bytes, 4752 sectors
Disk /dev/loop12: 3.7 MiB, 3887104 bytes, 7592 sectors
Disk /dev/loop13: 238.6 MiB, 250220544 bytes, 488712 sectors
Disk /dev/loop14: 91.1 MiB, 95494144 bytes, 186512 sectors
Disk /dev/loop15: 89.5 MiB, 93835264 bytes, 183272 sectors
Disk /dev/loop16: 14.5 MiB, 15208448 bytes, 29704 sectors
Disk /dev/loop17: 91 MiB, 95408128 bytes, 186344 sectors
here is my additional driver i chose: enter image description here
here is a screenshot of what happening after waking up in suspend state.
enter image description here and here is snap list output
Name                     Version         Rev   Tracking  Publisher   Notes
core                     16-2.37.1       6350  stable    canonical✓  core
core18                   18              677   stable    canonical✓  base
gnome-3-26-1604          3.26.0          74    stable/…  canonical✓  -
gnome-calculator         3.30.1          260   stable/…  canonical✓  -
gnome-characters         3.30.0          139   stable/…  canonical✓  -
gnome-logs               3.30.0          45    stable/…  canonical✓  -
gnome-system-monitor     3.30.0          57    stable/…  canonical✓  -
gtk-common-themes        0.1-4-g88bc1b2  818   stable/…  canonical✓  -
kde-frameworks-5-core18  5.54.0          26    stable    kde✓        -
ktouch                   18.12.1         27    stable    kde✓        -
Note: my laptop has Skylake Cpu(i7 6700HQ) which won't support with Linux kernel and it will stick in logo after installing ubuntu... after struggling to resolve this issue I come up with adding Nouveau in grub configuration and I managed to login in ubuntu eventually and now I have this problem.
I have been in your position partly where my computer started freezing on suspending after installing Nvidia Drivers. Nvidia drivers are known to create several problems in the computers, hence I don't recommend until you are sure that that's not the reason behind the issue.
I solved my problem by re-installing the default drivers (X.org). You could try the same. X.org drivers can be reinstalled by selecting the same from the Additional Drivers menu in your Ubuntu
Additional Drivers menu in my distro
or following these steps through your terminal.
Pang
  • 373
vipulgupta2048
  • 329
