I've been running Ubuntu 12.04 for a while now with no problems. Overall, the only kind of instability I've had is that the system will occasionally lock up completely under prolonged full cpu usage.
My current problem, though, is that Unity constantly freezes. Often, the whole thing doesn't freeze. Usually, only part of it freezes. For example, any open windows will lock up but the launcher will remain responsive, or vice-versa.
I can find no abnormal resource use associated with these freezes, though. That and the fact that I can often restore responsiveness by clicking somewhere on the status bar at the top make me inclined to think that this is a bug in Unity, and not, say, an issue with the graphics driver.
If it's of any use, though, I do have a PCIE Radeon card for which I am using the proprietary drivers, but I was able to use this for a month before I encountered this problem.
Another thing that I've noticed is that the problem often manifests itself the most soon after a start-up. As soon as the system runs for a few minutes, the problem becomes significantly reduced. Has anyone experienced something similar, and, of so, how did you fix it?
RolandiXor
  • 51,797
djpetti
  • 128
From what you described, it sounds like your experiencing a common issue with apt's update check, which runs as soon as you log in for the first time, and causes the CPU usage to spike for a while. It's harmless, and usually goes away after a few minutes.
In such cases, the best thing to do is to be patient and not do too much immediately after starting the system, since most systems (think, core2duo, 4GB Ram, and such like :), will not be able to handle the workload too smoothly.
Unfortunately, I don't know of any sure fire fix for this at this point in time.
RolandiXor
  • 51,797
