This problem is different than :
New asus with ubuntu keeps freezing
and
What should I do when Ubuntu freezes
Actually i have 3 major problems I'll list according to importance :
Couple of information first :
I'm using ubuntu 14.04 64bits on newly purchased Asus SonicMaster s551l with touchscreen , it comes with dual video cards Intel's and nvidia gforce gt 740m (I'm using proprietary drivers).
Problems :
1- when on battery mode (no charger pluged in) ubuntu keeps freezing every 3 minutes (average) meaning nothing works except sound (mouse doesn't move or click, screen stays still i.e when playing video stays on the same frame), example when i play video on youtube then it freezes the sound keeps playing , until now my solution was to close the laptop led wait a couple of seconds then login and every works as nothing happened .
this is ubuntu only problem cause it doesn't happen in windows i tested before i asked here .
2- Touch screen related issues : i have unity laucher on auto hide but it doesn't show up when i swipe from the sides , plus chrome tabs can't be selected dragged closed (by touching x) or even create new tab by touching the "+" button.
3- Function + bright buttons don't work (only these two) , I can't play with screen brightness using the keyboard (i can still through the setting though) .
the first problem caused by nvidia driver
if u dont have important files reinstall ubuntu then install nvidia proprietery driver ( NOT THE ONE TESTED , only PROPRIETERY ) then search in the dash for nvidia setting and set the graphic card as intel , the nvidia this time will not hang but it flikr a little thats why i told u to set intel as graph card
u cant set brightness using keyboard shortcuts in ubuntu as far as i know so dont bother
i have the same notebook except a non touch screen
if ur a normal user intel will be fine for every thing in ubuntu
1- You can also switch drivers without reinstalling:
  • Open the "Additional Drivers" utility
  • Select the driver you wish to use
  • Type your password
  • Wait for it install
  • Reboot
2 - Unfortunately I don't own a touchscreen and have now idea how to fix this. Maybe wait for Ubuntu 14.10? I heard it's supposed to be a lot better optimized for touch screens...
3 - For backlight support try installing this:
https://github.com/guillaumezin/nvidiabl/blob/master/install/deb/nvidiabl-dkms_0.87_all.deb
Then run this using Alt+F2 und enter you password:
pkexec sh -c "echo nvidiabl > /etc/modules-load.d/nvidiabl.conf"
and reboot.
ntninja
  • 736
