I am running the Ubuntu 14.10 with Gnome desktop. My machine is Lenovo t440s.
Specs: Processor: 4th Gen Intel® Core™ i7-4600U (4MB Cache, up to 3.30GHz) 12 GB RAM GPU: Intel® HD Graphics 4400
The issue is that my desktop will freeze. This happens randomly and will occur if I do something such as pressing a button or even pressing ctrl-shift-t for new tab once.
I am not sure if this is an issue with Gnome shell or the kernel.
This doesn't happen frequently, probably once every 4 hours. Its not really predictable.
Once it does freeze, I can move my mouse smoothly. The cursor will change into I shape if it hovers over text. However, I cannot click anywhere. I tried to ctrl-alt-f1 to switch to terminal, but that does not work. So I am forced to hold the power button to reboot.
I will provide more details if needed. Is there any way I can keep a resource log so that once it happens, I can see exactly which process is responsible?
Any suggestions on the source of the problem or a fix is welcome.
mrQWERTY
  • 145
DDR2 memory clock fixed at 200MHz in motherboard firmware BiOS CMOS setting solved my Random Screen Garble Freeze bug related to NViDiA graphics processor driver, without any graphics driver update :)
DDR2 memory clock = "Auto" = old default
DDR2 memory clock = "200MHz" = new fix
motherboard = ASUS = M2N MX SE PLUS;
BiOS = version 602 AMi BiOS from ASUS; NViDiA graphics chip = GeForce6150SE; DDR2 = 4GB( 2GB+2GB ) Transcend
"Auto" setting in BiOS CMOS was defaulting to 400MHz DDR2 memory clock which used to randomly freeze & garble my display screen;
i gave up NViDiA driver update as it had many other issues like missing 1366x768 pixel option;
i used Ubuntu built-in xrandr & cvt for 1366x768 pixel screen setup, instead of using NViDiA graphics driver update ( just added the below 2 lines at the beginning of /etc/gdm/Init/Default text file:;
xrandr --newmode 1366 85.25 1368 1440 1576 1784 768 771 781 798
xrandr --addmode VGA-1 1366
i don't need NViDiA graphics driver update anymore
YVRao
