2 hours ago I installed Ubuntu while listening to music on my headphones (wubi install). I then also played music on Ubuntu just fine, yet when I rebooted into Windows, without doing anything else besides opening Chrome, my headphones stopped working.
Exact same problem as in this thread: headphones not working on Windows after installing Kubuntu 12.10, which was left with many doubts and no answer.
Luckily I have not done anything on windows after installing Ubuntu 12.10, nor have I mingled with the audio driver. I fixed the problem using some advice from a discussion thread by rebooting into Linux and forcing the laptop to shutdown by holding the power button (in order to prevent Linux from muting the headphone jack in a way that Windows doesn't see). The headphones now work like before, thus it is obviously a problem originating from Linux.
Although this trick works for now, and I assume that it will work as long as I never shutdown Linux properly, I would definitely like a proper solution to this.
The discussion thread where I was told to crash Linux: https://bbs.archlinux.org/viewtopic.php?id=146773
csiz
  • 131
I have had this problem also. You just have to shutdown from Ubuntu not restart. Once the computer is off start it and choose windows, everything should work just fine.
smak
  • 31
Have you tried this?
echo "options snd-hda-intel model=asus" | sudo tee -a /etc/modprobe.d/alsa-base.conf
Source: http://ubuntuforums.org/showthread.php?t=2022151
karel
  • 122,292
  • 133
  • 301
  • 332
I have had this problem too, but I have found a way around that.
What I do is when I'm done using Ubuntu, before restarting to go to Windows, I mute the speakers, plug in headphones and mute that too, before going to Windows. When I don't mute sound in Ubuntu, the laptop speakers work in Windows, but no audio comes from headphones.
This answer may not apply to you if this temporary solution does not work.
Hope this helps.
I have had a similar issue, if I am getting you right. To me it also happened after installing and using Ubuntu 12.04 for some time. Sound worked with laptop speakers, but not with headphones. I have tried several fixes that I don't remember now, but what helped was reinstalling drivers in Windows (8). As simple may this sound, this was the easiest fix and it worked in my case. Hope it helps. Good luck!
Eliah Kagan
  • 119,640
shuhrat.m
