I use ubuntu 16.04 LTS and have 2 GB RAM and 320 GB hard disk space in which the allocated space for OS usage is 100 GB and swap space and other for partitions. recently after updates while doing multitasking my screen freezes and I have to manually reboot my system from the start. any suggestions?
terminal output:
$ free -h
               total        used       free      shared  buff/cache   available
Mem:           1.8G        977M        157M        201M        746M        467M
Swap:            0B          0B          0B
swapon
$ swapon
df:
$ df
Filesystem     1K-blocks     Used Available Use% Mounted on
udev              942524        0    942524   0% /dev
tmpfs             192584     6120    186464   4% /run
/dev/sda6      103936232 10980932  87652568  12% /
tmpfs             962904    18980    943924   2% /dev/shm
tmpfs               5120        4      5116   1% /run/lock
tmpfs             962904        0    962904   0% /sys/fs/cgroup
cgmfs                100        0       100   0% /run/cgmanager/fs
tmpfs             192584       56    192528   1% /run/user/1000
Screenshot of gparted
blkid:
:~$ sudo blkid
/dev/sda1: UUID="7C7E5116262411BD" TYPE="ntfs" PARTUUID="01468a4c-01"
/dev/sda5: UUID="eed0dfa4-6e24-47fe-84bc-c598b144b116" TYPE="swap"
PARTUUID="01468a4c-05"
/dev/sda6: UUID="14a87b2f-9da8-487c-a6f5-03ddcea8bb25" TYPE="ext4"
PARTUUID="01468a4c-06"
cat /etc/fstab:
~$ cat /etc/fstab
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name
devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
# / was on /dev/sda6 during installation
UUID=14a87b2f-9da8-487c-a6f5-03ddcea8bb25 /               ext4
errors=remount-ro 0       1
# swap was on /dev/sda5 during installation
UUID=4acee253-61f3-4f36-857e-9cb045346e7b none            swap    sw
0       0
after doing the mentioned step 2
step 2:
$ swapon -a
$ swapon
NAME      TYPE      SIZE  USED PRIO
/dev/sda5 partition   2G 67.6M   -1
~$ free -h
Mem: 1.8G        1.1G        297M        159M        468M      367M
Swap:1.9G         67M        1.9G
PAM
  • 15
The problem is that you have very little RAM, and no swap available. So when you load up more than one application at a time, you run out of RAM.
We're going to have to make a swapfile or swap partition to solve the problem.
Step #1: (review the configuration)
  • lets review a screenshot of gparted, sudo blkid, cat /etc/fstab
Step #2: (quick fix)
  • open the terminal from the Unity dashboard
  • type gksudo gedit /etc/fstab
change this line:
UUID=4acee253-61f3-4f36-857e-9cb045346e7b  none  swap  sw   0   0
to this:
UUID=eed0dfa4-6e24-47fe-84bc-c598b144b116  none  swap  sw   0   0
  • save the file and quit gedit
  • type swapon -a
  • type swapon
Observe this:
/dev/sda5 partition 1.9G   0K   -1
  • type free -h
Observe this:
Swap:          1.9G          0B        1.9G
  • quit the terminal application
Step #3: (don't do this now, it's only a brief flowchart for the future)
  • boot to a Ubuntu Live DVD/USB
  • in gparted
    • swapoff on /dev/sda5
    • resize (shrink) the right side of /dev/sda6 by 2G
    • resize (extend) the left side of /dev/sda5 for 4G total
    • result is 4G swap (RAM x 2)
  • in terminal
    • swapoff
    • sudo mkswap /dev/sda5 # note new UUID
    • gksudo gedit /etc/fstab #edit new UUID into /etc/fstab
    • swapon -a
    • reboot
heynnema
  • 73,649
