My system recently hung up and nothing worked. Cursor, keys, Ctrl commands (like Esc, Alt+Delete), Alt+F4, everything hangs up.
Once, I saw my cousin slam some keys and a totally black screen opened, waiting for a command. It sort of opened from the top. It wasn't Type a Command box or the Terminal. Although he didn't open it when the computer hung, I guess that could still be opened?
Anyway, so what can be done besides a reboot?
BЈовић
  • 4,662
Abhimanyu
  • 1,423
There are few things you can do :
  • restart the window manager (see here how to do it). This will forcefully log you out
  • switch to command console and kill or restart the problematic program (ctrl+alt+F1 (or F2-F6)).
BЈовић
  • 4,662
IF Single Application Stop working the Use : xkill And Click X curser on un-Responding Application
If System Hangs use :- ALT+SysRq (print screen) + R E I S U B
Where :-
R: Switch to XLATE mode
E: Send Terminate signal to all processes except for init
I: Send Kill signal to all processes except for init
S: Sync all mounted file-systems
U: Remount file-systems as read-only
B: Reboot
If Not Any of These :- Enter CTRL+ALT+F1 login There,
install htop sudo apt-get install htop
run htop
find un-responding program
and type : f7 and then f10
or Enter the command : sudo service lightdm restart
Ashu_FalcoN
  • 2,118
It seems your 'gnome-session' got hung up.
Press the combination keys ctrl + alt + F1 (or F2 - F6). Then you get a console. Login with your credentials and you will get your command prompt, then type the command:
ps -x | grep gnome
Find the process id of 'gnome-session' from the output and kill the session using command:
kill -9 <process id> (eg: If your session process id is 2183 then kill -9 2183)
Then your gnome session will be logged out. You can re-login and continue without rebooting.
ATR
  • 403
