Possible Duplicate:
What should I do when Ubuntu freezes?
At least once a day I lose work on my (2 different) Intel i5 machines running Ubuntu 12.04. The entire system will freeze/lock-up/hang, and never return. At this point nothing works; even the caps lock key doesn't toggle the light on the keyboard; Ctrl-Alt-F1 won't do anything either.
askubuntu.com is apparently where I'm directed for support.
I suspect this is a kernel bug. But I simply can't keep losing work like this, so I'm anxious to try whatever it takes to get the thing reliably working.
Can you suggest
  1. something I can try to fix the problem
  2. an existing bug I can follow progress on and contribute to (from users/tester's POV)
  3. the most constructive way I can contribute to helping fix the problem, keeping in mind that I do need the computer (so can't do things that might "brick" it!)
artfulrobot
  • 8,733
Just wait, keep apt-get dist-upgradeing and hope things get better.
At least that's the only option I found available. And hey, they did get better. Still using 12.04 and now very rare to have a full freeze after a successful boot.
artfulrobot
  • 8,733
I had similar issues using 64bit 12.04.1... including mouse problems. I reinstalled and am slowly reloading applications to ID the issue. Ubuntu Forums discussions point to the use of Chrome or Chromium (in my case). After reinstalling, I am using only Firefox for the past 4 days and have not seen a lockup. Still reintroducing applications, but so far, I've avoided Chromium and the freezes are gone.
