-2
I currently use Ubuntu 13.04 on LG X110 notebook After last updating (on 28th August 2013) software doesn't work. It suddenly stops while I'm using it. Hardware still runs: I know because of the noise, but noise it has during doing no operation. Software doesn't work at all: desktop is frozen, mouse is blocked, any keyboard command gives no result. I already uninstalled Xubuntu, in case there was some bug with it, but it just doesn't matter.
Any suggestion?
If it is happening to you after installing a different operating system it is probably a hardware problem.
Sounds like you could have a problem with your ram. When you turn on your computer and grub loads, run memtest+ and let it run overnight. If it gives any errors then your ram is the issue and you should replace it.
Anake
  • 1,955
