-1
I'm not sure the of the model name, nor if that would help, but I believe it is this: Hp 2000 Notebook PC 2000-2b09wm.
For some reason it likes to freeze randomly. I tried using the proprietary graphics driver, but that didn't help, except for make the experience unbearable. I am using Ubuntu 13.04, as any earlier versions are worse, and this version can handle all my hardware perfectly (It's also extraordinarily stable).
The overall specs:
  • AMD E-300 1.3Ghz Dual Core APU
  • 4GB RAM
  • 64-bit system, 32-bit OS (This isn't the problem, or at least, not the only problem, as 64-bit works just as bad.)
This computer came with UEFI boot, but I disabled it in the BIOS Settings, and continued to change the hard drive from GPT to MS-DOS
I'm kind of a newbie, so please, if there is anything else you would like to know ask away.
Seth
  • 59,332
The first things to analyze the problem is to look into the logfiles of the system. If you go to a terminal and enter dmesg, you will get the messages of the running session.
In the terminal look at the log files in the folder
ls /var/log
where probably syslog will be most interesting for you. Try to figure out if there are messages just before the freeze - easily identified by the fact that any new session begins counting by 0 again. When you find some hint, post the corresponding lines and maybe someone can help.
The commands you want to use for reading the files are e.g.
tail -n 250 /var/log/syslog
which returns the last 250 lines of syslog. Ore you can go through the files line by line with
less /var/log/syslog
