How do I add a directory to the $PATH in Ubuntu and make the changes permanent?
- 36,350
- 11,280
Using ~/.profile to set $PATH
A path set in .bash_profile will only be set in a bash login shell (bash -l).
If you put your path in .profile it will be available to your complete desktop session. That means even metacity will use it.
For example ~/.profile:
if [ -d "$HOME/bin" ] ; then
PATH="$PATH:$HOME/bin"
fi
Btw, you can check the PATH variable of a process by looking at its environment in /proc/[pid]/environ (replace [pid] with the number from ps axf). E.g. use grep -z "^PATH" /proc/[pid]/environ
Note:
bash as a login shell doesn't parse .profile if either .bash_profile or .bash_login exists. From man bash :
it looks for ~/.bash_profile, ~/.bash_login, and ~/.profile, in that order, and reads and executes commands from the first one that exists and is readable.
See the answers below for information about .pam_environment, or .bashrc for interactive non-login shells, or set the value globally for all users by putting a script into /etc/profile.d/ or use /etc/X11/Xsession.d/ to affect the display managers session.
The recommended place to define permanent, system-wide environment variables applying to all users is in:
/etc/environment
(which is where the default PATH is defined)
This will work in desktop or console, gnome-terminal or TTY, rain or shine ;)
To edit, open the terminal and type:
sudoedit /etc/environment(or open the file using
sudoin your favorite text editor)
To make it work without rebooting, run . /etc/environment or source /etc/environment. Since this file is just a simple script it will run and assign the new path to the PATH environment variable. To check run env and see the PATH value in the listing.
Related:
I think the canonical way in Ubuntu is:
create a new file under
/etc/profile.d/sudo vi /etc/profile.d/SCRIPT_NAME.shadd there:
export PATH="$PATH:YOUR_PATH_WITHOUT_TRAILING_SLASH"and give it execute permission
sudo chmod a+x /etc/profile.d/SCRIPT_NAME.sh
- 991
- 2
- 12
- 26
- 817
For complete newbies (like I am) who are more comfortable with GUI:
- Open your
$HOMEfolder. - Go to View → Show Hidden Files or press Ctrl + H.
- Right click on
.profileand click on Open With Text Editor. - Scroll to the bottom and add
PATH="$PATH:/my/path/foo". - Save.
- Log out and log back in to apply changes (let Ubuntu actually load
.profile).
For persistent environment variables available to particular users only. I highly recommend Ubuntu official documentation.
https://help.ubuntu.com/community/EnvironmentVariables
Referring to documentation above, I have setup my Android SDK path-tools by:
- creating
~/.pam_environmentfile in home directory. - the content of which is
PATH DEFAULT=${PATH}:~/android-sdk-linux/tools. - additional custom user path can be added by separating paths with colon (:).
- this requires re-login, which means you need to log-out and log-in back to desktop environment.
- 631
Put that line in your ~/.bashrc file.
It gets sourced whenever you open a terminal
EDIT: Based on the comments below, for a more general setting that will apply to all shells (including when you hit Alt-F2 in Unity), add the line to your ~/.profile file. Probably shouldn't do both however, as the path will be added twice to your PATH environment if you open a terminal.
- 10,126
- 3,533
- 22
- 25
Adding it to .bashrc will work but I think the more traditional way of setting up your path variables is in .bash_profile by adding the following lines.
PATH=$PATH:/my/path/foo
export PATH
According to this thread it appears as though Ubuntu's behavior is slightly different than RedHat and clones.
- 973
To set it system wide, append the line export PATH=/path/you're/adding:$PATH to the end of /etc/profile.
To add the directory for only the logged-in user, append the same line to ~/.bash_profile.
- 1,846
- 271
In terminal, cd to the_directory_you_want_to_add_in_the_path
echo "export PATH=$(pwd):\${PATH}" >> ~/.bashrc
This wasn't my idea. I found this way to export path at this blog here.
add there
export PATH=YOUR_PATH_WITHOUT_TRAILING_SLASH:$PATH
- 73,717
The recommended way to edit your PATH is from /etc/environment file
Example output of /etc/environment:
PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games"
For example, to add the new path of /home/username/mydir
PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/home/username/mydir"
Then, reboot your PC.
System-wide environment variables
A suitable file for environment variable settings that affect the system as a whole (rather than just a particular user) is /etc/environment. An alternative is to create a file for the purpose in the /etc/profile.d directory.
/etc/environment
This file is specifically meant for system-wide environment variable settings. It is not a script file, but rather consists of assignment expressions, one per line.
Note: Variable expansion does not work in /etc/environment.
More info can be found here: EnvironmentVariables
Whenever I "install" my folder of BASH scripts, I follow the pattern of the test for a $HOME/bin folder that's in most .profile files in recent versions of Ubuntu. I set a test that looks like
if [ -d "/usr/scripts" ]; then
PATH="/usr/scripts:$PATH"
fi
It works just about 100% of the time, and leaves me free to change it in a GUI text editor with a quick "Replace all" should I ever decide to move /scripts somewhere closer to my $HOME folder. I haven't done so in 6 Ubuntu installs, but there's "always tomorrow." S
BZT
- 463
Open your terminal, type gedit .profile and insert the following:
# set PATH so it includes user's private bin if it exists
fi
#the following line add Bin where you dont have a Bin folder on your $HOME
PATH="$PATH:/home/mongo/Documents/mongodb-linux-i686-2.2.2/bin"
Close and open terminal, it should be working.
- 55,453
- 61
Even if system scripts do not use this,
in any of the cases that one wants to add a path (e.g., $HOME/bin) to the PATH environment variable, one should use
PATH="${PATH:+${PATH}:}$HOME/bin"
for appending (instead of PATH="$PATH:$HOME/bin"),
and
PATH="$HOME/bin${PATH:+:${PATH}}"
for prepending (instead of PATH="$HOME/bin:$PATH").
This avoids the spurious leading/trailing colon when $PATH is initially empty, which can have undesired effects.
For Ubuntu edit the ~/.bashrc and add the following line.
. ~/.bash_profile
Then edit your .bash_profile as you need.....
- 73,717
