I have to versions of a software (Tecplot). When I write "tec360" in the terminal it brings me the old version. How can I change the program call directory so that it will bring me the new version?
Shibli
  • 157
If you want to keep both versions and start the version which is installed in your home directory when you type tec360, then add the full path of tec360 to your PATH. For example, if the path of tec360 is ~/tp/bin, then add:
export PATH=$HOME/tp/bin:$PATH
See also:
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
Move the new version you have installed to your /opt directory and replace the old one with the new one. Then have a system restart.
something like
sudo mv ~/tecplot /opt/
If you are not root , then do as follows in your terminal
gedit .bashrc
write a line at the end of the opened text file as
alias tec360="~/tp/bin/tec360"
Then save and close the text file.
Then in the terminal write as
source ~/.bashrc
now try again by calling your program.
Raja G
  • 105,327
  • 107
  • 262
  • 331
