How can achieve what you can see below? I read this question but did not succeed. My OS is Lubuntu 13.10 which is based in Ubuntu 13.10
You are technically ready to go, but
there's one extra step that I like to do to make command line debugging nice
and quick. I create a bash script called "php-xdebug", which automatically
starts the debugger engine. The script looks like this (unix only): >
#!/bin/bash
export XDEBUG_CONFIG="idekey=xdebug"
/usr/bin/php "$@"
Run "chmod +x" on the file and put it somewhere in your $PATH list, and you can
then use this instead of php when debugging. For instance, instead of "php
myscript.php", run "php-xdebug myscript.php" to start the debugger session.
