I got an executable file(edit_envir) in /home/pshizh/Desktop/ directory. I updated /etc/environment file to make /home/pshizh/Desktop included in PATH. Then I ran command edit_envir in terminal, but it said "dit_envir command not found. However, after I copied file edit_envir to /usr/bin/ and ran command edit_envir in terminal again, it worked. Why? I'd really appreciate your help.
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
Don't edit the /etc/environment file!!! revert the changes and put it back as it originally were. Your system is supposed to work with multiple users. Imagine you create another user, say johndoe. Then what will happen when he logs in? he'll have, in his PATH variable your directory /home/pshizd/Desktop. I'm sure he doesn't care about that!
Instead, modify the PATH variable from within your own personal .bashrc file: add this snippet at the end of your .bashrc file:
PATH=/home/pshizd/Desktop:$PATH
Now wait, your own scripts are not supposed to be located on your Desktop. Instead, create a bin directory in your home directory, put your scripts there, and instead of the previous command in your .bashrc file, put this:
PATH=$HOME/bin:$PATH
If you modify the file .bashrc, the changes will only take effect in new terminals.
Now, if you want this script to be available to all users (e.g., you'll want johndoe to be able to execute it, yet he should not have access to your personal directory), the best place is to put the script in /usr/local/bin. This directory should already exist (create it if necessary), and should already be in every user's PATH. Check that by inspecting the /etc/profile file (but do not modify this file!); you could also grep PATH in there, as so (with some contextual lines):
grep -C4 PATH /etc/profile
you should see that /usr/local/bin is added to the user's PATH.
By the way, do not put your own commands in /usr/bin! This place is for your distribution's binaries, not your personal ones.
Regarding why it didn't work after modifying /etc/environment: you need to open a new terminal for changes to take effect.
After you edit /etc/environment file, if you want the change to take effect, you need to log out and log back in or to source that file in terminal as follow:
source /etc/environment
Anyway, this is not an indicated method to add a directory to the PATH. See the following post in this sense:
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
