Possible Duplicate:
How to add a directory to my path?
I need to use a program in my job. I followed the installation instructions of this PROGRAM. However, when I try to run it the message appears - program_that_I_want_to_run:Command not found
I know that it is a $PATH problem, but I tried the command line described in the instructions and it did not work.
Set environment variable CONFIG_PATH
export CONFIG_PATH=/my_path_to_PROGRAM/PROGRAM/config/
I am sure that I indicated correctly the path to access the config directory. No typing errors.
Help?
