I am using Ubuntu 16.04, I am facing the problem with conda command (conda: command not found). when I export path of Anaconda3/bin to $PATH conda command is working. if I open another Terminal and try to use the conda command it's not working (conda: command not found). after the export path each time then only it's working. can anyone help me to fix this error?
Asked
Active
Viewed 260 times
When you want to change your path, be sure to include the existing part as well. To do that, add $PATH in the new path definition.
export PATH="$PATH:/usr/bin"
Make sure that your /etc/environment is only re-read at reboot.
I think adding the $PATH in your ~/.bashrc can solve your problem.
