I've installed Ubuntu 17.04 (VirtualBox). But since I have Ubuntu 17.04, it seems like docker is not yet available for Ubuntu 17.04. Is there any workaround to install Docker on Ubuntu 17.04?
This is my commande line history:
2 curl -L https://github.com/docker/machine/releases/download/v0.10.0/docker-machine-`uname -s`-`uname -m` >/tmp/docker-machine && chmod +x /tmp/docker-machine && sudo cp /tmp/docker-machine /usr/local/bin/docker-machine
3 docker-machine version
4 docker pull ubuntu:latest
5 sudo apt-get update
6 sudo apt-get install linux-image-extra-$(uname -r) linux-image-extra-virtual
7 sudo apt-get install apt-transport-https ca-certificates curl software-properties-common
8 sudo curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo apt-key add -
9 sudo apt-key fingerprint 0EBFCD88
10 lsb_release -cs
11 sudo add-apt-repository "deb [arch=amd64] https://download.docker.com/linux/ubuntu \
$(lsb_release -cs) \
stable"
12 sudo apt-get update
13 sudo apt-get install docker-ce -y
This is the actual error:
user@user-vm:~$ sudo apt-get update
Hit:1 http://ch.archive.ubuntu.com/ubuntu zesty InRelease
Hit:2 http://ch.archive.ubuntu.com/ubuntu zesty-updates InRelease
Get:3 http://security.ubuntu.com/ubuntu zesty-security InRelease [89.2 kB]
Hit:4 http://ch.archive.ubuntu.com/ubuntu zesty-backports InRelease
Ign:5 https://download.docker.com/linux/ubuntu zesty InRelease
Ign:6 https://download.docker.com/linux/ubuntu zesty Release
Ign:7 https://download.docker.com/linux/ubuntu zesty/stable all Packages
Ign:8 https://download.docker.com/linux/ubuntu zesty/stable amd64 Packages
Ign:9 https://download.docker.com/linux/ubuntu zesty/stable Translation-en_US
Ign:10 https://download.docker.com/linux/ubuntu zesty/stable Translation-en
Ign:11 https://download.docker.com/linux/ubuntu zesty/stable all DEP-11 Metadata
Ign:12 https://download.docker.com/linux/ubuntu zesty/stable amd64 DEP-11 Metadata
Ign:13 https://download.docker.com/linux/ubuntu zesty/stable DEP-11 64x64 Icons
Err:8 https://download.docker.com/linux/ubuntu zesty/stable amd64 Packages
404 Not Found
Fetched 89.2 kB in 12s (7'258 B/s)
Reading package lists... Done
W: The repository 'https://download.docker.com/linux/ubuntu zesty Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: Failed to fetch https://download.docker.com/linux/ubuntu/dists/zesty/stable/binary-amd64/Packages 404 Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead.
