A new Question today :).
I've downloaded Sublime Text 2 for Linux (x32). Now I want to add it to the PATH-Variable. How does this work?
Greets,
Baldoius
Greets,
Baldoius
You can add only a directory path to path variable.Run the below commands on terminal to add a directory path to the PATH-Variable,
su root
PATH=$PATH:/path/to/the/directory
To add the path permanently, add the following line at the end of ~/.bashrcfile
sudo gedit ~/.bashrc
Add the below line at the end,
export PATH=$PATH:/path/to/the/directory
