-1
I get this error when I run
\curl -L  https://get.rvm.io | bash -s stable:
Command 'bash' is available in '/bin/bash'
The command could not be located because '/bin' is not included in the PATH environment variable.
bash: command not found
curl: (23) Failed writing body (0 != 15640)
Anyone know how to fix this?
muru
  • 207,228
You are missing /bin: (where bash lives) on your path. The information on resolving that is in this related post
Elder Geek
  • 36,752
-1
Your $PATH has got some issues. Why twice /usr/bin is being mentioned.it needs to be fixed first. Essentially /usr/bin should be in the path.
My path entry is
echo $PATH
/opt/anaconda2/bin:/opt/anaconda2/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/opt/gradle/bin
Note : recently i installed anaconda so it is in front of other default and i should be correcting that.
Also in case you don't have curl installed then try installing it
sudo apt-get install curl
Ashu
  • 4,004
