34
I think I understand the instructions given in How to add a directory to the PATH? about adding directories to $PATH. But I don't understand how to add directories to $MANPATH or $INFOPATH.
Also -- in googling around for help I have noticed that sometimes directions say export PATH=/usr/share/lib/something:$PATH and sometimes they say export PATH=$PATH:/usr/share/lib/something. Which is it?
  1. These 2 are almost the same:
    The only difference is that the first one puts the directory to add in front and the second one puts it behind the current directories in $PATH. It only matters if there are commands inside /usr/share/lib/something that have the same name inside one of the directories in $PATH.
  2. To add directories to $MANPATH or $INFOPATH as required from the link you posted you do that by changing the config files inside the link.
    It says to open the global version of bash.bashrc with:
    sudo vi /etc/bash.bashrc
    and to add at the end:
    PATH=/usr/local/texlive/2010/bin/x86_64-linux:$PATH; export PATH
    MANPATH=/usr/local/texlive/2010/texmf/doc/man:$MANPATH; export MANPATH
    INFOPATH=/usr/local/texlive/2010/texmf/doc/info:$INFOPATH; export INFOPATH
    This sets $PATH, $MANPATH and $INFOPATH. And it also tells you to edit /etc/manpath.config with:
    sudo vi /etc/manpath.config
    and to add
    MANPATH_MAP /usr/local/texlive/2010/bin/x86_64-linux /usr/local/texlive/2010/texmf/doc/man
    underneath # set up PATH to MANPATH mapping.
If you are unsure about this make a backup 1st (never a bad thing) with:
sudo cp /etc/bash.bashrc /etc/bash.backup_$(date +"%Y_%m_%d").bashrc
sudo cp /etc/manpath.config /etc/manpath.backup_$(date +"%Y_%m_%d").config
The weird string changes into the current date. If you mess up just copy the backup back over the original file:
$ touch test1
$ cp test1 test1.$(date +"%Y_%m_%d")
$ ls
test1  test1.2014_11_14
Rinzwind
  • 309,379
If your man pages are in /usr/local/myproject/man, all you need to do is add that to (the end of) /etc/manpath.config:
MANDATORY_MANPATH        /usr/local/myproject/man
user.dz
  • 49,176
Michel
  • 171
If you've bothered to check, by default the environment variable MANPATH does not exist in current versions of Ubuntu. Try this:
echo $PATH
echo $MANPATH
This is due to man's dependence on the command manpath. Run it from the command line, and you'll find that its output is (effectively) MANPATH, yet we already know that no variable MANPATH is defined (by default):
manpath
/usr/local/man:/usr/local/share/man:/usr/share/man
The directories where manuals reside is contained in /etc/manpath.config, and you can edit that file to add new folders. Try this; edit /etc/manpath.config, and then see the result by running manpath. If that's all you need (to add some folders containing manuals), this may be a good solution for you.
In my case, I needed to also set the order in which these manual folders were searched. I found no way to set order by editing /etc/manpath.config (please correct me if I missed that). But of course you can do that when you edit your PATH env var, and you can do the same with MANPATH as it turns out. Here are some possibilities:
  1. To specify MANPATH independent of manpath:
export MANPATH="/first/path/tomanuals:/second/path/tomanuals:etc/etc/etc"
You may get a warning from your system to the following effect:
manpath: warning: $MANPATH set, ignoring /etc/manpath.config
Which is exactly what we wanted.
  1. To augment manpath such that the folder being added is searched first:
export MANPATH="/some/dir/with/manuals/man:$(manpath)"
Of course you can change the order around to suit your needs.
  1. Finally if you screw up, or just want to return control to manpath, do this:
unset MANPATH
Seamus
  • 698
x:y:z:$PATH or $PATH:x:y:z?
Barely different. $PATH contains a :-separated list of places where bash (the shell/terminal) should check for a program.
For example if you type cat the way the terminal understands what that means is to look through the first, second, third elements of $PATH, then save the first location it finds for later invocations of cat.
If I have two different versions of a program in two different places, with one of them being preferred, and $PATH tells the shell to search in the wrong order, then there's a problem. Otherwise, no problem.
export
Open a terminal and type
echo $a
a=5
echo a
echo $a
You'll see that a=5 set the variable value and $a refers to the variable name, not the value.
Open a second terminal and type echo $a. It should again be blank.
The difference between export and assignment (=) is explained here: https://stackoverflow.com/questions/1158091/defining-a-variable-with-or-without-export.
