I have a folder. Inside of this folder is an executable called python. When I try to run python from the terminal it instead runs the python interpreter. How can I run the file called python?
- 1,462
Specify the path. If you're in the directory with the binary, that's as simple as:
./python
Or yes, do as Muru suggested and add it to the path. That said, changing the path could interfere with how applications (running under your user) call Python. If you deflect them to the wrong version, they may function incorrectly.
There is not a good way to override the global python.
It should point to the version that ships with Ubuntu.
- 299,380
Along with the other answers you can also use the full path to the executable. For example, if your python executable is in /home/user/some_dir/python then running the following command from in the terminal will do the job:
user@user-home:~$ /home/user/some_dir/python
For ease of use you can create an alias for the above command so that you don't have to type the full path every time, by just appending the it in your .bashrc file. To do so, run the following commands in the terminal:
user@user-home:~$ echo "alias local_python=/home/user/some_dir/python" >> /home/user/.bashrc
user@user-home:~$ source /home/user/.bashrc
****Important note: Here i have used local_python as the alias name, you can choose any name you want but don't use python or any other already installed binaries' names as name of the alias.
- 93,925
