A misleading situation
First of all, the so-called "ffmpeg" from the Ubuntu repository is not really ffmpeg from the FFmpeg project, but a fake version from a fork. It's a confusing situation. See:
Secondly, this fake "ffmpeg" (and avconv) are terribly buggy. FFmpeg development is very active, and using a recent version of real ffmpeg will most likely resolve this issue.
Getting the real ffmpeg
You have several options:
Each has their advantages and disadvantages as described above.
Using a static build
You just need to download the archive, extract it, and execute the binary. No compiling or installing is necessary:
wget http://ffmpeg.gusari.org/static/32bit/ffmpeg.static.32bit.2013-06-19.tar.gz
tar xzvf ffmpeg.static.32bit.2013-03-19.tar.gz
Now you can use it. You can either navigate to the directory containing ffmpeg, and run (notice the preceding ./):
./ffmpeg -i input ... output
...or provide the full path to it as in:
/home/andy/ffmpeg/ffmpeg -i input ... output
Choose your $PATH
If you want the real ffmpeg whenever you use the ffmpeg command without having to use ./ or having to provide a full path to the binary, then place the ffmpeg binary in the bin directory in your home:
mkdir ~/bin
mv ffmpeg ~/bin
hash -r
Now you can just run ffmpeg and you'll be ready to encode stuff. If you want to use a different directory other than ~/bin, then you will have to add the directory to your $PATH as shown in How to add a directory to my path?
Checking for spies
Now using the ffmpeg command should show something like (note the "FFmpeg developers" phrase):
$ ffmpeg
ffmpeg version N-54152-g730e07f Copyright (c) 2000-2013 the FFmpeg developers
If it shows the following then you'll know that you are cursed and the fake version is still being used (note the "Libav developers" phrase):
$ ffmpeg
ffmpeg version 0.8.5-6:0.8.5-0ubuntu0.12.10.1, Copyright (c) 2000-2012 the Libav developers
