I am trying to install poetry the recommended way on Ubuntu 20.04.3 LTS:
curl -sSL https://raw.githubusercontent.com/python-poetry/poetry/master/get-poetry.py | python -
When I do so, it says:
Command 'python' not found, did you mean:
command 'python3' from deb python3 command 'python' from deb python-is-python3
curl: (23) Failed writing body (485 != 1378)
Then I try python3
curl -sSL https://raw.githubusercontent.com/python-poetry/poetry/master/get-poetry.py | python3 -
The installation succeeds.
Afterwards when calling poetry --version to test the installation, I get:
poetry: command not found
Although I added poetry to PATH manually, in .bash_profile:
PATH=$PATH:~/poetry/bin
I also tried adding poetry to path in .bashrc similarly to this answer:
export PATH="~/poetry/bin:$PATH"
LuGeNat
  • 123
For the sake of posterity, the old approach the OP mentions to installing Poetry has been deprecated. As of 22 Sep 2022, they recommend using the following command for Linux:
curl -sSL https://install.python-poetry.org | python3 -
I used this on Ubuntu 20.04.4 LTS and everything went smoothly.
You add ~/poetry/bin to PATH, but it should be ~/.poetry/bin.
Regarding python is not available, you can (re)install python-is-python3 package via apt:
sudo apt install python-is-python3
pLumo
  • 27,991
