When you want to add a new value to the PATH system variable, you most likely add a new line to ~/.bashrc or ~/.bash_profile files.
For example, if you want to add /opt/netbeans/bin to PATH, you must add this line to the end of ~/.bashrc file:
export PATH=$PATH:/opt/netbeans/bin
Let's break this line down.
export PATH - Here we refer to the PATH variable
= - We want to assign it a new value using the = operator
(The rest of the string is the value that will be stored in the PATH)
$PATH - We assign the variable PATH to the value that was in the variable before the current command
: - We add a separator for the new value
/opt/netbeans/bin - And add a new value to the PATH
You must see all of your refers to the PATH variable in the ~/.bashrc or ~/.bash_profile files and make sure that you expand -
and not overwrite like this -
export PATH=/opt/netbeans/bin
the PATH variable
You must make sure, in every reference to the PATH you use $PATH: and your additional value after it
If it doesn't work, you may do something like this:
- Make sure, there is something like the next variable in
/etc/environment file and it never redefined in this file:
PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games"
- Add missing paths from the above
PATH variable to your PATH variable located in the /etc/environment
Before testing after each change in files don't remember to update your configs.
For example for ~/.bashrc file:
source `~/.bashrc`
