I use LaTeX and rubber to compile my tex sources via command line. The command I usually use is rubber --pdf test.tex && rubber --clean test.tex. How can I create a custom command so that I only have to type rubber text.tex or rubb text.tex (or something like this) for it to do the same as the long command above?
Asked
Active
Viewed 287 times
Til Hund
- 625
I would use something simple, like
#!/bin/bash
rubber --pdf $1 && rubber --clean $1
then you save it in a folder in your $PATH and you are done.
I usually suggest to create (if not present) the folder ~/bin to contain your user's scripts, and then add it to your $PATH variable, following this solution.
