I want to stop having to use sudo everytime I work in /var/www. How can I do that? I simply want to put all of my sites into this directory and work with them without too much pain.
- 178,446
- 2,115
Most answers here are not written with security in mind. It's good to get a feeling that running sudo each time is not very wise. If you make a typo (for example a single space in a wrong place, such as recursively deleting / var/www/dir, which means / and var/www/dir, instead of /var/www/dir—please do not attempt), you might trash your system.
Note: Starting with Apache 2.4.7 / Ubuntu 14.04, /var/www has been moved to /var/www/html Adjust the commands in this answer accordingly.
See:
Bad ideas:
chmod 777(sagarchalise) - this allows anyone with access to your system write into the directories and files and thereby allowing the intruder to execute any code under thewww-datauserchgrp -R www-data $HOME(cob) - this allowswww-datato read or write any files in the home directory. This is not keeping the Least Privilege rule in mindchown -R $USER:$USER /var/www(kv1dr) - unless the world has read permissions on/var/www, the webserver running underwww-datawill not be able to read (serve) the files. If the file is a public-accessible plain HTML document, it might not be an issue if the world can read the file. But if the file is a PHP file containing passwords, it is.
NOTE: in the below solutions, I've granted www-data write privileges. However, /usr/share/doc/base-passwd/users-and-groups.txt.gz states:
www-data
Some web servers run as www-data. Web content should not be owned by this user, or a compromised web server would be able to rewrite a web site. Data written out by web servers will be owned by www-data.
Where possible, do not grant write permissions to the www-data group. www-data only needs to be able to read the files so the webserver can serve it. The only case where www-data needs write permissions is for directories storing uploads and other locations which needs to be written.
Solution 1
Add yourself to the www-data group and set the setgid bit on the /var/www directory such that all newly created files inherit this group as well.
sudo gpasswd -a "$USER" www-data
Correct previously created files (assuming you to be the only user of /var/www):
sudo chown -R "$USER":www-data /var/www
find /var/www -type f -exec chmod 0660 {} \;
sudo find /var/www -type d -exec chmod 2770 {} \;
(even safer: use 640 or 2750 and manually chmod g+w file-or-dir that needs to be writable by the webserver)
Solution 2
Create a symlink for each project to your home directory. Say your project is located at ~/projects/foo and you want to have it located at /var/www/foo, run:
sudo ln -sT ~/projects/foo /var/www/foo
If your home directory has no execute bit (descend) set for other (for security reasons), change the group of it to www-data, but set the execute bit only (no read/write). Do the same for the ~/projects folder as it may contain other projects than www. (You don't need sudo if you have previously added your user to the www-data group.)
sudo chgrp www-data ~ ~/projects
chmod 710 ~ ~/projects
Set the group to www-data on ~/projects/foo and allow the webserver to read and write to files and files+directories and descend into directories:
sudo chgrp www-data ~/projects/foo
find ~/projects/foo -type f -exec chmod 660 {} \;
find ~/projects/foo -type d -exec chmod 2770 {} \;
Even safer: use 640 and 2750 by default and manually chmod files and directories that need to be writable by the webserver user. The setgid bit should be added only if you want every newly created file in ~/projects/foo to be accessible by the group.
From now on, you can access your site at http://localhost/foo and edit your project files in ~/projects/foo.
See also
- 119,640
- 178,446
Rather than storing my web sites in /var/www I place links there to the sites which are located in my home folder. I can freely edit, or add pages to my sites. When I happy with changes I then FTP to a hosting company where my domain name links.
- 3,583
Don'ts
Don't set file permissions to 777 (world-writable)
This is a significant security flaw, especially if you enable server-side scripting such as PHP. Unprivileged processes should not be able to write to files that would affect the website or, in the case of server-side scripting being used, execute arbitrary code.
Don't add yourself as a member of the www-data group and give it write permissions
The purpose of that group is that it is an unprivileged group that the server processes run as. They should only have read access to the website files where possible, for the same reasons as above.
Don't change the permissions of the Apache processes
The Apache child processes run as the
www-datauser and group by default, and this should not be altered. This is just a way of giving them no write permission to the filesystem.In certain circumstances you want your server-side scripts to be able to write to files, in which case only those files should be made writable by
www-dataand care needs to be taken to ensure security.
Dos
Set the files to be owned by yourself
If you are the only one, or the usual one, to modify certain files on the website, then it makes total sense just to take ownership of those files. Set their owner to
<your username>.You don't have to modify the server permissions for this, as the server will continue to get read-only access even when the files are owned by you.
Choose a sensible place to house the files (using DocumentRoot)
If
/var/wwwdoesn't make sense, you are welcome to place them elsewhere. If they are specific to your own development or testing, you could place them in your home directory. Or you can set up some directories in/srv.If you want to give group write access, create a new group for the purpose
Don't re-use a system group, because these are typically designed to have the access they currently have, and no more, for security reasons.
- 37,804
It's this simple. You neither need to enable apache 'UserDir' (not recommended) nor messing up with 'www-data' groups (apache group in case on Fedora)
Just create your project directory inside /var/www/html
cd /var/www/html
sudo mkdir my_project
Then just chown the project directory to your user.
sudo chown your_username my_project
Now you can start working on your project folder as a regular user with any editor, IDE of your choice. No more sudos : )
- 3,830
- 1
- 28
- 39
If you make /var/www writeable by its group and add yourself to the group, you will not have to use sudo while still being fairly secure. Try this:
sudo adduser <username> www-data
sudo chown -R www-data:www-data /var/www
sudo chmod -R g+rw /var/www
You should then be able to edit /var/www/ files without hassle.
The first line adds you to the www-data group, the second line clears up any files with messed up ownership, and the third makes it so that all users who are members of the www-data group can read and write all files in /var/www.
chmod in /var on www to allow the owner access, and chown to make sure you own it. Probably a stupid idea, but it would definitely work.
- 1,939
You could start a www-session in a terminal by
sudo su www-data
Combined with a differently colored prompt*, to make it more obvious that it is the shell of a different user, and a policy always to put the corresponding xterm (and editor and such) on - for example - the virtual desktop 4, so that you get used to it, to avoid confusion.
*) For a differently colored prompt with a differnt character, create a file /etc/prompt like this:
# PROMPTING
# When executing interactively, bash displays the primary prompt PS1 when it is ready to read a command, and the sec-
# ondary prompt PS2 when it needs more input to complete a command. Bash allows these prompt strings to be customized
# by inserting a number of backslash-escaped special characters that are decoded as follows:
# \a an ASCII bell character (07)
# \d the date in "Weekday Month Date" format (e.g., "Tue May 26")
# \D{format}
# the format is passed to strftime(3) and the result is inserted into the prompt string; an empty format
# results in a locale-specific time representation. The braces are required
# \e an ASCII escape character (033)
# \h the hostname up to the first `.'
# \H the hostname
# \j the number of jobs currently managed by the shell
# \l the basename of the shell's terminal device name
# \n newline
# \r carriage return
# \s the name of the shell, the basename of $0 (the portion following the final slash)
# \t the current time in 24-hour HH:MM:SS format
# \T the current time in 12-hour HH:MM:SS format
# \@ the current time in 12-hour am/pm format
# \A the current time in 24-hour HH:MM format
# \u the username of the current user
# \v the version of bash (e.g., 2.00)
# \V the release of bash, version + patchelvel (e.g., 2.00.0)
# \w the current working directory
# \W the basename of the current working directory
# \! the history number of this command
# \# the command number of this command
# \$ if the effective UID is 0, a #, otherwise a $
# \nnn the character corresponding to the octal number nnn
# \\ a backslash
# \[ begin a sequence of non-printing characters, which could be used to embed a terminal control sequence
# into the prompt
# \] end a sequence of non-printing characters
# The command number and the history number are usually different: the history number of a command is its position in
# the history list, which may include commands restored from the history file (see HISTORY below), while the command
# number is the position in the sequence of commands executed during the current shell session. After the string is
# colors:
# \[...\] wird benötigt, damit die shell weiß, daß hier kein printable output ist, und die Umbrüche richtig plaziert.
# ANSI COLORS
CRE="\[
[K\]"
NORMAL="\[[0;39m\]"
# RED: Failure or error message
RED="\[[1;31m\]"
# GREEN: Success message
GREEN="\[[1;32m\]"
# YELLOW: Descriptions
YELLOW="\[[1;33m\]"
# BLUE: System messages
BLUE="\[[1;34m\]"
# MAGENTA: Found devices or drivers
MAGENTA="\[[1;35m\]"
# CYAN: Questions
CYAN="\[[1;36m\]"
# BOLD WHITE: Hint
WHITE="\[[1;37m\]"
# default:
# postgres, oracle, www-data
# PS1=$BLUE"machine]->"$NORMAL\\w"$BLUE ø $NORMAL"
PS1=$BLUE"machine]:"$NORMAL\\w"$BLUE > $NORMAL"
# root, stefan:
case "$UID" in
'0')
PS1=$RED"machine:"$NORMAL\\w"$RED # $NORMAL"
'1000')
PS1=$GREEN"machine:"$BLUE\\w$YELLOW" > "$NORMAL
# default)
esac
and source it from /etc/bash.bashrc for instance.
As additional tool to help distinction, you could always edit your files with an alias 'edit' or a symlink, which points, depending on your identity (taylor/www-data) to either gedit or mousepad, vim or pico. Or you could use different editor profiles, at least in gedit you may set your preferences to black text on white ground or white text on black ground for instance.
I only have such a policy for working as root, so I'm not sure how good it will fit to working with www-data. Combined with ssh-sessions to differnt hosts, which have their own prompts, it didn't stop me from being sometimes wrong, but if it happens, I realize fast, what is wrong, and it happens rarely.
note: The prompt-script is partly a copy of the manpage of bash.
- 6,892
This variation is much like Lekensteyn's first solution, where www-data is given sticky read-only access, and a specific user has write access.
It also allows directory traversal in cases where you might grant specific privileges on certain files or subdirectories, after setting the base permissions.
The general form is like this:
u=YOURUSER
g=www-data
d=/var/www/html
chown -R "$u:$g" "$d" &&
find "$d" \! -type d -print0 | sudo xargs -r0 chmod u=rwX,g=r,o= &&
find "$d" -type d -print0 | sudo xargs -r0 chmod u=rwx,g=rxs,o=x
The parentheses are only if you run this from your regular shell so the variables don't pollute it.
Using xargs for such operations is more efficient as it will invoke as few chmod commands as possible (probably just one), whereas -exec in find will run a separate command for every single file & dir.
Another difference is that the chmod invocations don't use the less-legible numeric permissions, and the X preserves the execute bit on files that already have it, e.g. scripts.
You can put that in a script to run as necessary, or in a cron job, but it would have to been run as root, so you would remove the sudo from it.
If YOURUSER is you, you should no longer need sudo.
If it's some application-specific, isolated account, then you still use sudo, but not as root, e.g.:
sudo -u YOURUSER bash
- 452
