On Raspberry Pi, I log in as the default user Pi.
I do a sudo git clone on a repository, because it needs to create directories.
This is specific for DNU/DNX, because we cannot run sudo dnu restore yet, or ever? I don't know. It gets permission denied on the packages file causing it to error and I cant run the sample.
pi@raspberrypi ~/Home/samples/1.0.0-beta4/HelloMvc $ dnu restore
Restoring packages for /home/pi/Home/samples/1.0.0-beta4/HelloMvc/project.json
Writing lock file /home/pi/Home/samples/1.0.0-beta4/HelloMvc/project.lock.json
System.UnauthorizedAccessException: Access to the path "/home/pi/Home/samples/1.0.0-beta4/HelloMvc/project.lock.json" is denied.
I had to do a chmod -R 0777 /Samples but that obviously is not the correct way to fix this.
How can I safely or easily use sudo git clone but then make everything as if Pi user did the clone, or allow the Pi user to work properly.
I did try chmod Pi:Pi on the specific packages file but that didn't help. I didn't try it recursively but I don't really know how to do this properly.
So I did a fresh clone as requested in comments, let see whats going on.
pi@raspberrypi /home/test $ sudo git clone https://github.com/aspnet/Home.git
pi@raspberrypi /home/test $ stat /home/test/Home
File: `/home/test/Home'
Size: 4096 Blocks: 8 IO Block: 4096 directory
Device: b302h/45826d Inode: 153225 Links: 4
Access: (0755/drwxr-xr-x) Uid: ( 0/ root) Gid: ( 0/ root)
Access: 2015-06-23 20:42:42.819728005 +0000
Modify: 2015-06-23 20:42:48.649688508 +0000
Change: 2015-06-23 20:42:48.649688508 +0000
Birth: -
File: `/home/test'
Device: b302h/45826d Inode: 153224 Links: 3
Access: 2015-06-23 20:42:31.099806322 +0000
Modify: 2015-06-23 20:42:42.819728005 +0000
Change: 2015-06-23 20:42:42.819728005 +0000
Birth: -
pi@raspberrypi /home/test $ stat /home/pi
File: `/home/pi'
Device: b302h/45826d Inode: 29 Links: 7
Access: (0755/drwxr-xr-x) Uid: ( 1000/ pi) Gid: ( 1000/ pi)
Access: 2015-02-16 15:09:21.453774622 +0000
Modify: 2015-06-23 19:33:46.613016792 +0000
Change: 2015-06-23 19:33:46.613016792 +0000
Birth: -
