I created a Laravel project using my user. But now I added code that creates folders and files. The files and folders created by the PHP code are owned by www-data user and group. So when I check ownerships and permissions inside the root directory, I see the entire project is a mix of different ownerships for the folders and files, of my user and www-data.
That happened because the project itself was created by me so most of the files are owned by my user name and user group.
But now as I work on the project, I'm writing code that makes the web server create files and folders and it's owned by www-data user and group.
The problem is I am using VSCode Remote (with SSH) and then I can't access/edit the files created by the server with my user so I just chown every time, because I'm currently working on a file storing script. So I want to see if my script worked and created the correct files so I have to chown it right now to access them
But how can I make my user be able to also view/edit the files created by www-data securely without needing to chown every time?
I know there are a few approaches and I was recommended by some to use setfacl command. Or maybe I should add my user to www-data group? But I was told me this approach is bad (in production) because if someone gets access to the web server he gets access to the entire system.
What would be a good practice to allow my user to access (read/write) files created by the server.
Also, since the rest of the project is owned by me (not newly created files), should I also changed that to be owned by www-data?
Foobarer
  • 517
