I am try to make a file readable and writable by apache web server. I have use the following command:
sudo chgrp apache /var/www/html/itdb/data/itdb.db
When I try to run the php application I get the message:
var/www/html/itdb is not writeable by apache
make /var/www/html/itdb/data/files/ writeable by the user running the web server
in unix:
chown www-data /var/www/html/itdb/data/files/; chmod u+w /var/www/html/itdb/data/files/
A.B.
  • 92,125
in your attempt:
you're setting group "apache" as owner of this resource
and script is complaining:
and even giving you solution:
(probably you might want to run those with sudo to ensure success)
Good luck
A.B.
  • 92,125
