I would like to execute the command gedit file.txt as a root with sudo e.g.:
sudo gedit file.txt
should ask me for a root password.
Currently, typing sudo gedit file.txt results in:
[sudo] password for currently_logged_in_user:
After typing the password, it results in:
currently_logged_in_user is not in the sudoers file.
This incident will be reported.
So I have to use su root gedit file.txt instead which is inconvenient.
Anderson
  • 119
david
  • 113
sudo does not work the way you envision.
You can configure sudo to allow root access to commands, such as gedit, but not specify files. So if you give a user root access to gedit, the user can edit any system file.
Example, for the user joe
joe     ALL = /usr/bin/gedit
would grant root access to gedit , but the user could then access and edit any file.
In addition, by default, the root account of Ubuntu is locked and sudo uses the invoking users password rather then a root password. Sudo is however highly configurable so you do not have to access root, you can specify an alternate user with the -u flag. You may then configure sudo to use the target password, root or otherwise. You would have to set a root password.
See http://www.gratisoft.us/sudo/sudoers.man.html and https://help.ubuntu.com/community/RootSudofor details
I think you will want to change ownership on the file in question so the file is owned by root:some_group, add the user to some_group and allow group edits.
Example - How to avoid using sudo when working in /var/www?
Thus gedit does NOT run as root, and the user can edit the file with group permissions.
If you need finer grain control use acl.
If you really wish to confine a use use apparmor.
Panther
  • 104,528
it seems your user doesn't have administrative rights and therefore can't invoke sudo. However changing to root user does work. The solution would be to make your current account have administrator rights.
You can do this if you log in to your administrator account and then change it via user accounts.
Minos
  • 1,821
