I work in Ubuntu 14.04. Well, I always had the misconception that installing a software from the root user makes the software available to all users. So, I wanted to install apache and add my html pages over there. I installed apache using root user. It installed successfully.
Then to test apache, I typed localhost, and the default page came up successfully. So then I thought about changing the index.html page and adding my code. I was making all my .html files in gedit, and thus tried to change index.html in gedit. When I tried to open it, it told me I could open it in only read-only mode, and I could not change it. Then I figured out that I could not change the permissions, nor change the file in the normal user.
I thought about it for a while, and thought removing the index.html file and adding my on file would work. But it didn't.
Then I uninstalled apache and re-installed it from normal user. Still I couldn't change the index.html in normal user.
So is there a way, to access and change the index.html file of apache installed in root in normal user?
NOTE: I know the password of root, and can even uninstall apache and install it again. This is on my personal computer.
