I’m a developer. A few days ago I started using Laravel on Ubuntu. When I use the terminal to create a new directory it appears with a padlock on it. Even logged in as root I have to give it permission with chmod.
How can I create directories with all permissions for all kind of users?
Zanna
  • 72,312
When using laravel on Ubuntu you want to set it up in the following ways that will ensure you don't use or need root access for the created files.
  1. Location of created projects should be in /var/www/html folder but can be anywhere.
  2. Install composer and set that up globally so you can install laravel globally with it.
  3. The permissions in /var/www/html need to be set up such that you don't need root privileges to operate on files there as it is in your case.
Install Composer:
curl -sS https://getcomposer.org/installer | php
sudo mv composer.phar /usr/local/bin/composer
sudo chmod +x /usr/local/bin/composer
Check Install:
composer -V
Install laravel using composer:
composer global require "laravel/installer=~1.1"
Check install:
laravel -V
Setup folder permissions for laravel:
  1. Temporary setup in /var/www/html:
    • Add self to group www-data:
      sudo usermod -a -G www-data $USER
    • Change ownership of laravel folder:
      sudo chgrp -R www-data /var/www/html/project
    • Tip: to setup laravel storage:
      sudo chmod -R 775 /var/www/html/project/storage
  2. Permanent solution:
    • Make default ownership of folders in /var/www/html $USER:www-data, so any new creation will assume the permissions of your user and the group www-data
      sudo setfacl -d -R -m u:$USER:rwx,g:www-data:rwx,o:rx /var/www/html
Now simply add any user to the www-data group to have them have rwx access to any created laravel project in /var/www/html. A reboot will be required.
Usage:
laravel new /var/www/html/new-project
muru
  • 207,228
George Udosen
  • 37,534
mkdir -m a=rwx myDir
or
mkdir --mode=a=rwx myDir
Run mkdir --help for more info.
karel
  • 122,292
  • 133
  • 301
  • 332
