I've got apache2 running on Ubuntu Server 12.04 LTS on an old laptop. It's on my local network to act as a webserver to help me learn PHP (and linux).
The default owner for the /var/www folder (where the webpages for apache are stored) is www-data. With the owner set to www-data I can't copy files/folders to that folder over ftp. If I change the owner of the /var/www folder to james (my ftp user) then I can move files over ftp but apache doesn't have access to display any pages or sub folders.
What should the correct owner be to allow access for ftp user james and apache?
Erresen
  • 279
I'd recommend setting it to be owned by james:james.
Alternatively, you could leave it as root:root and requite sudo for anybody deploying files in there, but if you are directly working in the /var/www directory (rather than working somewhere else and pushing the files there) that may not be convenient, and it won't work with FTP either.
You can set the owner of /var/www to whatever you like, as long as the www-data user has read access. You can achieve this by setting permissions to allow world read access (as is default).
By default, it is owned by root:root (not www-data as you state in the question).
  • For security, it is not a good idea to set it to be owned by www-data. www-data is intended to be an unprivileged account which cannot write to any files, and can only read them.
    Yes, occasionally you may need to give www-data the permission to write to a given file, but for security this should be strictly limited to those particular files, and precautions should be taken such as making sure no such files are executable as scripts by the web server (ie they are not in a location where they may be interpreted as PHP or CGI files), etc.
  • For security, it is an even worse idea to set the file permissions to world-writable (eg, 777). Unprivileged users such as www-data should not be able to write to files in this directory. The only people who need write access will be the people who are actually writing files in there.
  • The /var/www directory is intended to be yours to do with what you like. It makes sense to set ownership to whichever account will be editing the files. You can create a group for this purpose if you have multiple people, but in this case it's just you.
    Note: if creating a group, create a new group. Do not re-use the www-data group as that is intended to be an unprivileged group without write access to any files (as I explain above).
Too often I see people recommending adopting very bad security practices such as setting /var/www to be owned by www-data, or adding people to the www-data group in order to give that group editing privileges, or setting /var/www to be world-writable (eg 777). By doing any of this you are potentially opening yourself up to significant security problems.
thomasrutter
  • 37,804
The ideal permission is to make yourself the owner and the www-data the group, set youself as the owner of files by sudo chown -R yourname:www-data /var/www/public_html/ and sudo chmod -R g+w /var/www/public_html/ make sure you change the directory and username appropriately. You will be able to write files and apache processes wont be hindered. I am suggesting this as the OP is running a local instance of APACHE for practice purpose and will be using lots of scripts or opensource scripts like wordpress, etc, that will require write access. Here security is not a prime concern as the local server will not be using a public ip and ease of installing, copying and running scripts is of prime importance. The OP can focus on learning PHP rather than administering the server.
Ads
  • 186
