I had trouble fixing the file uploading, but then I ran chmod a+w /var/www and it worked - files were being uploaded to my specified directory.
However, my script also generates a thumbnail immediately after the file is uploaded. This part is not working. I'm assuming that the files uploaded by the script are locked (they have a small lock appearing near them when going to the directory manually) and it can't grab the uploaded file and create a new thumbnail file based on it.
I'm not getting any error or something.
How do I edit the permissions in the way that lets me create new files using "locked" files?
aborted
  • 269
You just need to work out your permissions correctly. If this is a web application than the user doing the file manipulation is probably www-data. So all files and directories need to be owned by the www-data group and user. And www-data should have full permissions for those files and directories.
  1. Give www-data ownership of all files and dirs in DocumentRoot: sudo chown -R www-data:www-data /var/www.
  2. Change permission so www-data has rwx priveleges: sudo chmod -R 775 /var/www.
  3. Add yourself to the www-data group so you can make changes as well: sudo adduser <username> www-data. Logout and back in.
  4. Read up on unix privileges and maybe tweak the permission within /var/www to be a bit tighter.
Dan
  • 6,784
