I want to modify sudoers so that users in the group www-data can switch to the user www-data without a password. I know it is possible, but I don't want to break my system. Here's what I have so far:
%www-data: ALL=NOPASSWD: /usr/bin/sudo -u www-data
But I am not sure this will work. My purpose in doing this is to let the permissions in /var/www/ remain 755 and yet allow the group to make changes. Otherwise Drupal and other CMS systems send out warnings.
muru
  • 207,228
The rule should actually be:
%www-data ALL = (www-data) NOPASSWD: *
The specification in the brackets (Runas in sudoers) is to specify the target user (and/or group) (the one you specify using -u).
That said, what you should actually be doing is setting correct permissions, including the setgid bit. How to avoid using sudo when working in /var/www?
muru
  • 207,228
