I installed XAMPP but I need to edit folders and files in there. I did the following
groupadd lampp
usermod -a -G lampp kyle
chown -R root:www-pub /var/www
chmod 2775 /opt/lampp
find /var/www -type d -exec chmod 2775 {} +
find /var/www -type f -exec chmod 0664 {} +
(Above code from here) So ya, I logged out then back in and nothing changed. So ya any help would be awesome Thanks - FRED
you need to add yourself to the www-pub group
plus /opt/lamp is not the same as /var/www
sudo groupadd www-pub #I am not sure if you need this
sudo usermod -a -G www-pub kyle
sudo chown -R root:www-pub /var/www
sudo chown -R root:www-pub /opt/lamp
sudo find /var/www -type d -exec chmod 2775 {} +
sudo find /var/www -type f -exec chmod 0664 {} +
sudo find /opt/lamp -type d -exec chmod 2775 {} +
sudo find /opt/lamp -type f -exec chmod 0664 {} +
BUT you probably need EITHER /opt/lamp or /var/www , not both
Then log out and back in.
See also How to avoid using sudo when working in /var/www?
Panther
  • 104,528
