if i'm not owner
i'm using visual studio editor
i can't change the code in any file in /var/www/html/
because of this command
sudo chown -Rf www-data:www-data /var/www/html/
i need to know how can i be able to change the files
sudo -Rf chown www-data:username /var/www/html/
sudo chmod -Rf 775 /var/www/html/
those lines can help !?
I'm V
  • 31
The folder /var/www/html is owned by user www-data and group www-data. So, as suggested by @Serg, the solution is to add yourself to the group that owns this file, in this case: the group www-data:
sudo usermod -G www-data username
Then, change permissions of the directory to 775:
chmod -R 775 /var/www/html
and you should be able to edit the file.
Jos
  • 30,529
  • 89
  • 96
