Installing the apache2 package in Ubuntu is all you need to host files, and most likely the easiest solution since it is available in the repositories and comes with basic configuration.
sudo apt-get install apache2
After installing the package, a directory will be created at /var/www. Now each time someone tries accessing your browser from a browser will be welcomed by the index page of that directory.
By default, it contains an "It Works!" message, and it's located at
/var/www/index.html
If you remove that file, the browser will instead show a listing of files in that folder.
Thus each file you need to let other computers see in your browser should be located inside that directory.
It can be reached by http://_YOUR_LOCAL_IP_ADDRESS_/
Note: By default, and for security reasons, the /var/www directory is not writable for any user. Check this question and answers for more details on that: How to avoid using sudo when working in /var/www?
After installing Apache, you stop or start the service by typing one of the following respectively:
sudo apache2ctl stop
sudo apache2ctl start
Of course, this isn't all you can do with Apache, but as solution for your problem there isn't more that needs be done.
