$ mv DVWA-master /var/www/html
mv: cannot move 'DVWA-master' to '/var/www/html/DVWA-master': Permission denied
How can I fix it?
I want to move a folder in /var/www/html.
Zanna
  • 72,312
haldar
The meaning of the error is:
The user which execute the mv command doesn't have write permission to the folder /var/www/html
If you need to move a file or a folder to the /var/www/html/ folder, and you have sudo permissions, you'll be able to do it using:
sudo mv DVWA-master /var/www/html
Yaron
  • 13,453
Do
and check the permission of the main folder with :
ls -l /var/www/html
and
ls -l /var/www
As you put data in the www folder, I'm thinking that could be the folder of apache content. So, you should to apply a chown for get the apache application access to the new sub folder DVWA-master.
dubis
  • 197
