I am new to Ubuntu and I wanted to host a server on it.
I googled a bit and read something about Apache and IIS and I couldn't get much out of it. Right now I am confused about how to proceed.
What I want to do is
  • Host server on local PC and set up virtual hosts on same PC
  • in virtual host, have “myname.com” opened in browser
Any relevant links which could serve as a tutorial?
Sorry if it has been already asked, it would be kind of you if you could redirect to that thread.
Tasdik Rahman
  • 457
  • 22
The two most common tools for this are the Apache and nginx servers.
Notes:
  • You'll need to edit a few system configuration files. If you're uncomfortable with vim, replace vim with nano, or gedit in the following commands. For example, sudo vim will become sudo -H gedit or sudo nano.
  • Once you're done setting it up, have a look at How to avoid using sudo when working in /var/www?
  • A more detailed guide is available from the Ubuntu LTS Server Guide.
Apache
First, install Apache:
sudo apt-get install apache2
The Apache configuration files are located in /etc/apache2. You'll typically be interested in:
  • /etc/apache2/sites-available - contains the Virtual Host definitions. Definitions are enabled and disabled using the a2ensite and a2dissite commands. The enabled site definitions are linked to /etc/apache2/sites-enabled.
  • /etc/apache2/conf-available - contains custom configuration files. They are enabled and disabled using the a2enconf and a2disconf commands. The enabled site configuration files are linked to /etc/apache2/conf-enabled.
  • /var/www/html - the default directory that Apache serves.
For most instructions, I'll assume we are in /etc/apache2.
VirtualHost setup
Let us create a new site. There's a default configuration available in sites-enabled/default.conf. We will make a copy of this, and work on it:
sudo cp sites-available/000-default.conf sites-available/my-name.conf
sudo vim sites-available/my-name.conf
Change the ServerName, so that it uses, for example, myname.com:
ServerName myname.com
Change the DocumentRoot, so that it uses, for example, /var/www/my-name:
DocumentRoot /var/www/my-name
Save the file, and enable it:
sudo a2ensite my-site
Now, we need to set up the directory for the site:
sudo mkdir /var/www/my-name
We'll set permissions for convenience:
sudo chown $USER:www-data /var/www/my-name
sudo chmod g+s /var/www/my-name
Add a few HTML files here.
Since the virtual host is to run locally, we need to map myname.com to a local address. To do this, we need to edit /etc/hosts:
sudo vim /etc/hosts
Add a line like so:
127.0.0.2 myname.com myname
Save, and then restart Apache:
sudo service apache2 restart
Now, you can browse to http://myname.com or http://myname, and the contents of /var/www/my-name will be displayed.
muru
  • 207,228
