I need to edit my php.ini file so I can upload large sql files into MySQL, but I don't know how to do it.
If I go to var/www/html and try and drag-and-drop phpinfo.php there it won't let me (not enough permissions).
Can someone please tell me how to edit the permissions of the folder so I can add files to it? (terminal method is preferred, but UI is fine too).
Sage
  • 219
You should not change the permissions and you should not use a command from which you do not know what it does and what impact it has.
Copy the file using the terminal with proper access privileges:
sudo cp /path/to/your/phpinfo.php /var/www/html
And the following access rights should be enough for phpinfo.php
sudo chmod 640 /path/to/your/phpinfo.php
A.B.
  • 92,125
