I'd like to use php includes to streamline the process of making a few web pages. The problem with that, however, is that I can't seem to test them locally. They work fine on the server, but my computer doesn't seem to understand them. I tried installing php and apache but it didn't seem to work. What do I need to do to set up a php testing server locally?
Jonathan
  • 7,470
Install the package libapache2-mod-php5 (which will also install the package for the webserver: apache2). Files can be put in /var/www.
If you then open http://localhost/index.html in your browser, /var/www/index.html is displayed.
The default settings are pretty secure, PHP errors are logged to /var/log/apache2/error_log and not showed in the browser. To change this on a development machine, edit /etc/php5/apache2/php.ini and change display_errors = Off to display_errors = On.
Some modules are not installed by default. If you do image processing, you likely need the GD library for PHP, package php5-gd. To get a list of all available modules, open a terminal, type sudo apt-get install php5- and hit Tab twice to get a list.
See also: How to avoid using sudo when working in /var/www?
Lekensteyn
  • 178,446
Install taskel & the LAMP stack
sudo apt-get install tasksel
sudo tasksel install lamp-server
You should now have an apache server with php and mysql.
