securing my server i found that using:
find . -type f -exec chmod 400 {} \;
find . -type d -exec chmod 500 {} \;
display 403 forbidden access.
if I use:
find . -type f -exec chmod 644 {} \;
find . -type d -exec chmod 755 {} \;
the server displays but i can have access from the internet to some folders directories.
my current folder owners are root - www-data for var/www/domain/public.
i would like to perform 400-500 permissions with my website displaying results on the internet with current www-data user, or another option could be to block directory display of folders. any help appreciated.
s_h
  • 113
The files need r and directory needs to be rx by the user www-data.
So, with what you want ...
find . -type f -exec chmod 440 {} \;
find . -type d -exec chmod 550 {} \;
Just make SURE you run that command from /var/www and not /
See also How to avoid using sudo when working in /var/www? or similar.
You may need looser permissions depending on what you are doing in /var/www. You may need to allow rwx on directories where users would download files, such as avatars on forums for example, or allowing x on CGI .
Panther
  • 104,528
