188
I'm trying to install the flashybrid but when I enter the apt-get install flashybrid command, I get this error:
root@user-desktop:/home/user# apt-get install flashybrid
Reading package lists... Done
Building dependency tree
flashybrid is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0B of additional disk space will be used.
debconf: DbDriver "config": /var/cache/debconf/config.dat is locked by another process: Resource temporarily unavailable
Setting up flashybrid (0.15+nmu2) ...
dpkg: error processing flashybrid (--configure):
subprocess post-installation script returned error exit status 1
flashybrid
I also tried this one to find what is already using that file:
root@user-desktop:/home/user# lsof | grep /var/cache/debconf/config.dat
lsof: WARNING: can't stat() fuse.gvfs-fuse-daemon file system /home/user/.gvfs
Output information may be incomplete.
dpkg-prec 4672 root 4rW REG 8,6 39658 1697827 /var/cache/debconf/config.dat
But I don't know how to fix this.
Braiam
  • 69,112
Dimitris7
  • 1,881
6 Answers6
294
A solution to this locking problem is detailed in the wiki:
sudo fuser -v /var/cache/debconf/config.dat
Will show you what process is holding the lock:
                     USER        PID ACCESS COMMAND
/var/cache/debconf/config.dat:
                     root      18210 F.... dpkg-preconfigu
Then you simply need to note down the PID and kill it like so:
sudo kill PID
sudo kill -9 PID  # if the first doesn't work
Sayed Jalil Hassan
  • 3,053
  • 14
This is more simple one command
I just did:
sudo rm /var/cache/debconf/*.dat
After I run the apt-get install and (I was installing curl ) and it worked restored the db manual pages.
PS: I removed something with apt-get and I did have this problem. but solved it simply thank also to @rajagenupula
ucefkh
  • 1,790
17
  1. open your terminal
  2. open the location /var/cache/debconf with gksu nautilus
  3. move (cut/paste) all of the .dat files to another backup directory.
  4. attempt to run again (will likely get a different error)
  5. restore those dat files from the aforementioned backup directory.
  6. Then try again what you were doing (should work this time).
Kijewski
  • 107
Raja G
  • 105,327
  • 107
  • 262
  • 331
17
sudo fuser -vik /var/cache/debconf/config.dat
Will display the process and ask if you want to terminate it.
coderpatros
  • 367
If you are getting this error in an unattended script, make sure you don't accidentally have two consecutive apt-get upgrade or apt-get dist-upgrade commands running, otherwise the second command can fail to obtain the lock and thus end up in this error.
Mahn
  • 121
There is a process still running blocking debconf. You should wait until it finish. Or find out how it got stuck, since in some cases it will be try to ask you a question but since you don't have a scope to see it. If you wait sometime and things doesn't change you may need to reboot the system, or terminate the process.
sudo kill 4672
or
sudo killall dpkg-prec
This will assure you that your database will not get damaged and will prevent further problems.
Braiam
  • 69,112
