Reading package lists... Done
Building dependency tree... Done
The following additional packages will be installed:
binutils binutils-common binutils-x86-64-linux-gnu build-essential bzip2 cpp cpp-13
cpp-13-x86-64-linux-gnu cpp-x86-64-linux-gnu dirmngr dpkg-dev fakeroot fontconfig-config fonts-dejavu-core
fonts-dejavu-mono g++ g++-13 g++-13-x86-64-linux-gnu g++-x86-64-linux-gnu gcc gcc-13 gcc-13-base
gcc-13-x86-64-linux-gnu gcc-x86-64-linux-gnu gnupg gnupg-l10n gnupg-utils gpg gpg-agent gpg-wks-client
gpg-wks-server gpgconf gpgsm javascript-common libabsl20230802 libalgorithm-diff-perl
libalgorithm-diff-xs-perl libalgorithm-merge-perl libaom3 libasan8 libassuan0 libatomic1 libavif16
libbinutils libbz2-1.0 libc-bin libc-dev-bin libc-devtools libc-l10n libc6-dev libcc1-0 libcrypt-dev
libctf-nobfd0 libctf0 libdav1d7 libde265-0 libdeflate0 libdpkg-perl libexpat1 libexpat1-dev libfakeroot
libfile-fcntllock-perl libfontconfig1 libfreetype6 libgav1-1 libgcc-13-dev libgd3 libgomp1 libgprofng0
libheif-plugin-aomenc libheif-plugin-dav1d libheif-plugin-libde265 libheif-plugin-x265 libheif1 libhwasan0
libisl23 libitm1 libjbig0 libjpeg62-turbo libjs-jquery libjs-sphinxdoc libjs-underscore libksba8 liblerc4
liblsan0 liblzma5 libmpc3 libmpfr6 libnpth0t64 libnsl-dev libnuma1 libpng16-16 libpython3-dev
libpython3.11 libpython3.11-dev libquadmath0 librav1e0 libsframe1 libsharpyuv0 libstdc++-13-dev
libsvtav1enc1d1 libtiff6 libtirpc-dev libtsan2 libubsan1 libwebp7 libx265-199 libxpm4 libyuv0
linux-libc-dev locales-all make manpages manpages-dev pinentry-curses python3-dev python3-distutils
python3-lib2to3 python3-wheel python3.11-dev rpcsvc-proto xz-utils zlib1g-dev
Suggested packages:
binutils-doc gprofng-gui bzip2-doc cpp-doc gcc-13-locales cpp-13-doc pinentry-gnome3 tor debian-keyring
g++-multilib g++-13-multilib gcc-13-doc gcc-multilib autoconf automake libtool flex bison gdb gcc-doc
gcc-13-multilib gdb-x86-64-linux-gnu parcimonie xloadimage scdaemon apache2 | lighttpd | httpd glibc-doc
bzr libgd-tools libheif-plugin-ffmpegdec libheif-plugin-jpegdec libheif-plugin-jpegenc
libheif-plugin-j2kdec libheif-plugin-j2kenc libheif-plugin-rav1e libheif-plugin-svtenc libstdc++-13-doc
make-doc pinentry-doc python3-setuptools
Recommended packages:
gnupg
The following NEW packages will be installed:
libbinutils libc-dev-bin libc-devtools libc6-dev libcc1-0 libcrypt-dev libctf-nobfd0 libctf0 libdav1d7
libde265-0 libdeflate0 libdpkg-perl libexpat1-dev libfakeroot libfile-fcntllock-perl libfontconfig1
libfreetype6 libgav1-1 libgcc-13-dev libgd3 libgomp1 libgprofng0 libheif-plugin-aomenc
libheif-plugin-dav1d libheif-plugin-libde265 libheif-plugin-x265 libheif1 libhwasan0 libisl23 libitm1
libjbig0 libjpeg62-turbo libjs-jquery libjs-sphinxdoc libjs-underscore libksba8 liblerc4 liblsan0 libmpc3
libmpfr6 libnpth0t64 libnsl-dev libnuma1 libpng16-16 libpython3-dev libpython3.11 libpython3.11-dev
libquadmath0 librav1e0 libsframe1 libsharpyuv0 libstdc++-13-dev libsvtav1enc1d1 libtiff6 libtirpc-dev
libtsan2 libubsan1 libwebp7 libx265-199 libxpm4 libyuv0 linux-libc-dev make manpages manpages-dev
pinentry-curses python3-dev python3-distutils python3-lib2to3 python3-pip python3-wheel python3.11-dev
The following packages will be upgraded:
libbz2-1.0 libc-bin libc-l10n libexpat1 liblzma5 locales-all
6 upgraded, 118 newly installed, 0 to remove and 69 not upgraded.
1 not fully installed or removed.
Need to get 0 B/118 MB of archives.
After this operation, 409 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
debconf: DbDriver "config": /var/cache/debconf/config.dat is locked by another process: Resource temporarily unavailable
Setting up libc6:amd64 (2.37-15) ...
dpkg: error processing package libc6:amd64 (--configure):
installed libc6:amd64 package post-installation script subprocess returned error exit status 1
libc6:amd64
E: Sub-process /usr/bin/dpkg returned an error code (1)```
Asked
Active
Viewed 68 times
