I am trying to remove mysql with the following commands:
sudo apt purge mysql-*
sudo apt autoremove
and got these errors:
dpkg: error processing package mysql-server-5.7 (--remove):
installed mysql-server-5.7 package pre-removal script subprocess returned error exit status 1
debconf: DbDriver "config": /var/cache/debconf/config.dat is locked by another process: Resource temporarily unavailable
dpkg: error while cleaning up:
installed mysql-server-5.7 package post-installation script subprocess returned error exit status 1
mysql-server-5.7
what can I do to remove this mysql-server-5.7
. After sudo apt-get install -f
I got:
dpkg: error processing package mysql-server-5.7 (--configure):
Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
mysql-server-5.7
dpkg -s mysql-server-5.7
Package: mysql-server-5.7
Status: install ok half-configured
Priority: optional
Section: database
Installed-Size: 46369
Maintainer: Ubuntu Developers <ubuntu-devel-discuss@lists.ubuntu.com>
Architecture: amd64
Source: mysql-5.7
Version: 5.7.28-0ubuntu0.18.04.4
Replaces: mysql-client-5.5, mysql-server-5.5, mysql-server-5.6 (<< 5.7), virtual-mysql-server
Provides: virtual-mysql-server
Depends: bsdutils, lsb-base (>= 3.0-10), mysql-client-5.7 (>= 5.7.28-0ubuntu0.18.04.4), mysql-common (>= 5.8+1.0.4~), mysql-server-core-5.7 (= 5.7.28-0ubuntu0.18.04.4), passwd, perl (>= 5.6), psmisc, debconf (>= 0.5) | debconf-2.0, libc6 (>= 2.14), libevent-core-2.1-6 (>= 2.1.8-stable), libgcc1 (>= 1:3.0), liblz4-1 (>= 0.0~r127), libssl1.1 (>= 1.1.1), libstdc++6 (>= 5.2), zlib1g (>= 1:1.1.4)
Pre-Depends: adduser (>= 3.40), debconf, mysql-common (>= 5.5)
Recommends: libhtml-template-perl
Suggests: mailx, tinyca
Breaks: mysql-server-5.6 (<< 5.7)
Conflicts: mysql-client-5.5, mysql-server-5.5, virtual-mysql-server
Conffiles:
/etc/apparmor.d/usr.sbin.mysqld 7faefe6d3d191f1e9ec1094ac8e0b159
/etc/init.d/mysql 89a1a5b6ad710389112802fc3fbb81e1
/etc/init/mysql.conf 5b097f4a577d63c60a8f6ca01b12bc47
/etc/logcheck/ignore.d.paranoid/mysql-server-5_7 6babe46e791059cdd5a26f4f7fec9eca
/etc/logcheck/ignore.d.server/mysql-server-5_7 2d34a7ed83fefc165cd1dfea3a72ccc8
/etc/logcheck/ignore.d.workstation/mysql-server-5_7 2d34a7ed83fefc165cd1dfea3a72ccc8
/etc/logrotate.d/mysql-server b3c32cbc55b042b1fe76698c8e928974
/etc/mysql/debian-start 68f4d300f151fd3facec50d0bcf009ef
/etc/mysql/mysql.cnf f5d3113b607567fd2ce955f4279fa9ce
/etc/mysql/mysql.conf.d/mysqld.cnf cae4bc0923e3a19cdfe3c85c06fbbfb7
/etc/mysql/mysql.conf.d/mysqld_safe_syslog.cnf 347fa9f3d579ffc06c39bf7e69f4fc6e
Description: MySQL database server binaries and system database setup
MySQL is a fast, stable and true multi-user, multi-threaded SQL database
server. SQL (Structured Query Language) is the most popular database query
language in the world. The main goals of MySQL are speed, robustness and
ease of use.
This package contains all the infrastructure needed to setup system
databases.
Homepage: http://dev.mysql.com/
